BTW way in 10speed you can get ultegra 11-28 assumed we were talking 10 speed as 9 speed is sooo obsolete
OP’s 3rd post:
10 speeds not an option at the moment as I’ve not got enough to buy a new drive train.
But you’re a racer IIRC and I’m guessing speed means more to you than cleaning stuff – other way round for me
I am indeed a racer, but if I couldn’t clean stuff I wouldn’t stick with the limited ratios – I’ve not had to walk a climb in years, literally. And like I say, I’ve not found a single climb that I couldn’t climb comfortably with a double that could be done with a triple, and single is proving fine, albeit a bit more of a grind in places! I am on a lighter bike than you (I expect!), which helps, and I’m possibly fitter, which also helps.
There’s a climb near me which is steep, with a very steep rooty bit in the middle. Took me a few attemps to clean it, but once I got the knack it’s fine. Higher gear is easier, you carry more speed, and don’t stall on the roots. I’ve never seen anyone get up it, racer or otherwise, in a 22/32 type gear, you can’t get over the roots. Admittedly it requires a bit more fitness to push the bigger gear, but like I say, I don’t find really low gears any use at all. YMMV.
