The Xbox One doesn’t (yet) support HDMI-CEC which (I’m guessing) is what the PS3 is using to talk the TV. (In Samsung parlance this is ‘Anynet’, but that’s just a branding on top of a standard).
What you can do though, the One has an IR blaster. So you can set it up so that when you switch on the Xbox it’ll power up your TV etc by essentially pretending to be a TV remote control. Likewise, you can use it to shut everything off.
It’s under something like Settings / Power or Settings / Startup or some such, I can’t remember exactly. It’s not as slick as CEC, and won’t work the other way (ie, the TV powering up the Xbox), but it’s better than nowt.
