Viewing 9 posts - 1 through 9 (of 9 total)
  • X0 DH chainset
  • emmodd
    I’ve just bought the above to fit my Yeti which needs a 73mm bb but the cranks that has come doesn’t say what width they are ie; 68/73mm or 83mm. Any ideas on how I check/what I measure? These are the ones i’ve bought http://www.chainreactioncycles.com/Models.aspx?ModelID=74774
    Thanks peeps.
    ruscle
    say’s in description that it comes with a GXP83 bottom bracket. So its got a 83mm bottom bracket.
    honourablegeorge
    I think you have the right one, despite the description – the one below is the 93mm one.
    http://www.chainreactioncycles.com/Models.aspx?ModelID=74776
    Put the BB cups onto the sleeve and measure the distance between their inside edges – should be 75.5mm.
    emmodd
    Honourablegeorge – that was exactly my thinking. Despite the description, there is no bb either!
    Hob-Nob
    I’m not sure you have bought the right ones. AFAIK the only difference between the X-0 DH & normal crankset is the DH is only available in 83mm BB. Other than that, there is no difference to the crank arms.
    If you are running a 1×10 with a 68/73mm BB, you should have bought the X-0 3×10 setup (that’s my understanding of it anyway).
    emmodd
    I’m not sure now. Sram say otherwise – http://www.bikeradar.com/news/article/sram-x0-dh-downhill-groupset-first-look-30783/
    Also, CRC have this listed http://www.chainreactioncycles.com/Models.aspx?ModelID=74776 which is different from the gpx one I have ordered
    emmodd
    Wiggle do something similar in terms of listing. Anyone else agree i’m safe to assume that unless it says GXP 83mm, it’s a 68/73mm width?
    emmodd
    Anyone? [list]
    creaser
    i was thinking the same was going to get one for my 224 but from what i could see they only come in 83mm
The topic ‘X0 DH chainset’ is closed to new replies.
