I had the Sweep forks for a couple of months before I got all ‘keeping up with the Joneses’ and bought some Rockshox for 3 times as much (they’re maybe 5% better).
Anyway, I’m not sure how close the Sweep and Trace forks are, but mine were pretty good, especially given the cost – mine had rebound adjust and a knob that was ladled Compression, but really had two settings – off and lock you could leave the lever half-way, but I never got the feeling it was a setting thing per-se and it would be just my luck for it to jump to lock half way down a rock garden or something.
My forks worked at very lower pressure compared to Fox and RS, I’m 16st but I seem to recall they were at 60psi at 30%
Once they were bedded in they were very plush and worked wonderfully most of the time, their only drawback being the lack of compression adjustment meant that in in extreme cases they would blow through travel – I they would be weight tuned they’d be perfect, I guess they’d be perfect for a lighter rider too.
I’d guess you’re are either not sagging right because they seals are new and sticking a bit, or it’s not well.
