...on a budget.
I need the above bits to finish off a build for the missus, so what've you got that's cheap?
Christian
...on a budget.
Christian
EDIT (bars sold so adjusted appropriately)
Can do you;
Truvativ Husselfelt stem 50mm, with FSA Gravity Gap cranks (no chainrings) & near new shimano bottom bracket for £41 posted. Add a fiver for some lockon Pink Ruffians or Renthal (brand new) medium compound grips. Add £8 for a 160mm Avid G2 rotor.
Any good to you?
Deore shifters?
http://www.singletrackworld.com/forum/topic/clearout-revelations-hope-hoops-and-few-bits-and-bobs
Hi, I have Sunn Origine OS bars and stem (new), X7 shifters (new) and Truvativ Firex 3.1 cranks (new), also lightly used Avid Elixir 4 brakes. All in I was looking for £195 - could do the lot for £165?
Los
Any good to you?
2x Avid Rotors 185mm G2CS - £12.50 each
Race Face Evolve 44t 9-spd outer ring – Black/silver
Race Face x-type 22t Silver – 9-spd
£10 for these 2 rings as they are not new
Shimano XT 22t ring in black – 9-spd - New £7.50
Truvativ XCDH Riser Bar in black 680mm 50mm rise TEAM AL 7050 - £10.00
All pictures are here
Dobo - I could be interested in the big ring, would you swap it for anything? See here:
http://www.singletrackworld.com/forum/topic/huge-clearout-bmx-mtb-brakes-rotors-bars-stem-wheelsets-grips-far-more
Or how much as I don't need the inner ring?
I have a pair of black riser bars with a black fsa stem,
you can have them both for £10 posted.
mbydmt send you email, £7.50 for the 44t ring
veedubba
I also have some 25.4 race face bars and stem combo - £25 posted if your interested, nice and lightweight and come with some free grips
see here
Cranks, rings, bash and bottom bracket......
email rjpassmore@googlemail.com if interested, thanks
You must log in to post.
