Wanted - brake hose + fittings to suit shimano lx disc brakes. These take a non banjo fitting (SM-BH59). Does anyone have one lying around?
Thanks!
Thanks!
how long doe the hose need to be? - I may have some in the garage
Hmm. It's for a front brake so I would guess about 900mm. Only snag is I needed the threaded nut and cover to fit on it well, although if anyone had those separately?
sorry - just found some - off a Deore but I' pretty sure it uses the same connectors
You must log in to post.
