The 130mm u-turn type please, if anyone has one they've taken out please email me (email in profile)
Classifieds - Wanted
WTD: Revelation medium spring
Posted 4 months ago #
I've got one from a set of Pikes.
Posted 4 months ago # -
I have a stripped set of 09 coil u turn revs if your still after the spring?
Thanks for the replies. Pikes one is the same I think, how much do you want for it?
Thanks pitcher, I think the 09 ones are longer travel though 140mm?
I took it out of a set of 2007 426 Pikes I bought new at the start of 2008. Although the dates might be 2006 / 2007. Only been used on one ride before I swapped it out and has been sitting in the replacement springs 'transportation bag' ever since.
I'll check it tonight when I get home and give you any info I uncover.
If all is well £14.72 posted to you.
Morninge,
Right having checked the spring last night it's a 'red' which is medium and from 2007.
I gave TFT a quick ring to check compatability and they said if the Revs are 140mm it'll be fine. 130mm and the spring will be 10mm too long. Having re-read your OP I note that your need a 130mm one so mine won't fit properly.
D'oh! I've just checked and you're right, that's a shame, I thought the pikes were the same but with a biger axle. Thanks very much for doing the research!
No (i'm probably wrong on age) - they're 426's and 85-130mm
Sorry i missed this, that is the correct travel. How much do you want for it?
Thanks,
JulianPosted 4 months ago #
Reply
You must log in to post.
