As the title
Cheers!
Tim
As the title
Cheers!
Tim
Are the bulb ones any different to the Pro 2 ones? I assume you mean the 20mm plug in adaptors that allow you to run a qr fork?
Yeah got 20mm. After some end caps to run QR forks if required and for easier wheelbuilding.
Will find out if the caps are the same. Hope were closed this morning
Tim
Emailed Hope this morning re front Hope bulb qr adapters, they are looking at a production run in January depending on other production pressures, fingers crossed may be able to order soon.
You must log in to post.
