Hi,
I'm looking for a set of six disc rotor bolts. Also need Avid brake mount bolts, for frame & caliper washer would be a bonus.
Hi,
Rotor bolts are just M4's (small versions of your water bottle bolts) and the mount bolts are usually M5's. Do you know how long the brake mount bolts need to be? if you're using an adaptor for a bigger rotor then I'll need to take that into account.
Let me see what I've got in store at home and report back. I should have enough either way.
hi Im just using a 160 rotor so I think a 20/25mm bolt should be fine.
Thanks
yep, got loads of those in stainless & high tensile. Let me take a few pics tonight and you can choose.
TRH
YGM
You must log in to post.
