Caliper only wanted but would buy full brake if necessary. anyone got one 'lying around' by any chance?
email in profile
cheers
email in profile
cheers
Not 100% sure, but aren't Juicy calipers all the same...?
Worth checking as it might make your search much easier, especially if (I'm guessing) you've a damaged one you could swap the hardware (ti bolts?) across from...
Best of luck,
Pete
I'm after a master cylinder + lever...so if you end up with a complete brake drop me a line.
