Viewing 4 posts - 1 through 4 (of 4 total)
  • Wrong rear mech? Currently top-pull, can I used a side-pull?
  • pealy
    Quick question – currently have an SLX rear mech that pulls from the top and have (on impulse) bought one used that looks like it is probably designed for side-pull. Can I use it do you think?
    And yes, I do mean Rear mech, not front.
    Thanks.
    njee20
    WTF!? All rear mechs pull the same. Unless you mean low-normal (cable pulls mech down to small sprockets) or top-normal (more common, cable pulls mech to bigger sprockets).
    Either way, as long as you have a Shimano shifter it'll definitely work, the function may just be reversed.
    There is no such thing as side-pull or top-pull on rear mechs.
    wwaswas
    shadow mechs have the cable entering nearer the top if that's what you mean.
    If you want to use a standard mech you may need a longer gear cable and a bit of new outer to make a smooth run into the mech.
    pealy
    I think that's probably what I mean.. Thanks
The topic ‘Wrong rear mech? Currently top-pull, can I used a side-pull?’ is closed to new replies.
