Girlfriend’s Octavia vRS; open bonnet, unplug stuff, unscrew stuff, remove headlamp, work out which bulb is which (bloody H7 faff), change bulb, replace headlamp, reconnect loom, screw stuff back on, close bonnet. Probably 10 minutes at the outside.
My Partner spaz chariot; open bonnet, unplug connector, undo spring clip, change bulb, spring clip back on, connector back on, close bonnet. Ah oldish stuff…just as easy to do as on my old Mog traveller.
306 estate here and a 1 minute job and that’s taking a wee break half way through.
Either your wee must come out at a heck of a rate, or you might want to get your prostate checked..
