Worst job must be screwing the pins into Hope F20 pedals – awful!!
Oh sweet jesus, yes. This ^^^.
Like loads of people, I’ve bled all kinds of brakes, serviced lots of forks and shocks, done frame bearings, laced wheels, serviced hubs, cut steerers, cut carbon bars, removed and pressed in headset cups, pressed in press-fit BBs etc…
Buy far the biggest PITA was the Hope F20 pins, I’d totally forgotten about that! You get one pedal done, and you really really can’t be arsed to do the next.
The only other thing that comes close is poorly done internal cable routing, sanding down the outer ends, then gorilla taping them together, I get a bit of a sweat on when pushing the new outer through.
