b r
tbh As I stated above, I think its a combination of your weight, where you ride and low-ish pressures.
I run lower pressures than you and live/ride in the Borders, so plenty of rocks – and haven’t had problems with Ardents (ran them on the rear all year), in fact I’ve just worn the tread off.
Maybe also your rims are too narrow/wide – what are they?
You’re probably right although it’s still a bit disappointing. Anyway, I guess I may need to be more realistic about how light I can go tyre wise given my weight etc.
Rims were Mavic 721 rear and a Sun Ringle EQ27 on the front so not really that wide or narrow. I’m now running a Flow EX rear and an 819 front both tubeless with Hans Dampfs, so will see how it goes.
