Yes that is a LIDL one.
The clamp on the lidl one is rubbish.
True.
If you do get one expect to spend some time modifying it. Carbon paste helps. Drilling a bolt through the head is better. Even bolted in one place the plastic clamp still flexes and creaks.
Also the legs rust. It is stable though – usually cause the front wheel slowly moves around and sits on the ground.
Mine now sits outside and gets used for the degrading bike washing duties.
Edit – and it doesnt have a QR clamp so its slow to tighten up while you balance the bike in your other hand.
