- This topic has 57 replies, 29 voices, and was last updated 9 years ago by cookeaa.
Woodburnerists; how much did you do yourself/cost.
duckmanFull Member
Chimney swept and tested,stove bought and hearth fitted. I know I need a liner and a flue pipe, at what point did you lot get the experts in? Approx cost would be good as well. It is a two story house so liner will be sore. Thanks, Stuart.
welshfarmerFull MemberNever. Did the lot. I built my house from scratch myself though. I did once get a man in to lay one carpet but that was because it came with free fitting. 🙂
Not dead yet
trail_ratFree MemberProfessionals did mine for the previous owner according to the certs stapled to the wall in the leccy cupboard.
Found too many regulatiom contraventions to list.
Most dangerous being distance from fixed combustables and a modified coal skuttle with the bottom cut out and welded to a plate for a register plate./flue adaptor.
So i ripped it out , and refitted as per regs with the help of my dad and grandad.. Infact we ripped it out again this year and fitted a new stove.
Choose your installer carefully
dylsFull MemberSupply/fit liner and stove, inc hetas certificate will be around £1200 – £1500 for the 904/904 grade liner. This would include the plate above the stove etc.
bokononFree MemberNo professional fitting here, just installed as per the regs by me and my father in law.
granny_ringFull MemberLiner, register plate, micafil insulation, cowel & fitting = £1100ish for us. Normal terrace in Kent.
Got 3 quotes and all around that price.sssiFree MemberI’ve done 2 stoves in our house. The first one was in the lounge so needed about 12m of liner and rockwool surround. With the register plate, cowl and vitreous pipe it was around £1k plus stove. I rather stupidly fitted the liner myself which involved 2 slings around the chimney, me standing on top of the chimney to feed the liner in and my wife belaying me.
The second time i took advantage of the scaffolding we had up whilst redoing the roof to install the liner into the upstairs bedroom. That was FAR easier… i do recommend scaffolding…
footflapsFull MemberI rather stupidly fitted the liner myself which involved 2 slings around the chimney, me standing on top of the chimney to feed the liner in and my wife belaying me.
It’s easier to pull the liner up from the bottom….
tonyf1Free MemberThe bad news – Failure to get a HETAS Certificate of Compliance signing off the installation can lead to a £5K fine. Also you won’t be able to provide this if you ever want to sell your house.
You can do the work yourself and then get it signed off by a HETAS engineer (if you can pursued one) but when I checked this route engineer wanted £500. TBH I would just get the professionals in which would be around £1200 ish round here in Gloucestershire. It’s tempting to try and reduce cost of installation but remember a badly fitted stove can kill!
trail_ratFree MemberAnd if you repeat that often enough tony folks will believe it .
You can also have your stove signed off by local building control provided you have followed due process and called them out at the correct points in the install.
5thElefantFree MemberIt’s tempting to try and reduce cost of installation but remember a badly fitted stove can kill!
Are there any stats on how many die from log burners? If I had to guess I’d say being hit by lightning was a greater risk.
trail_ratFree MemberWilling to bet more folk die from misuse of log burners than from bad instalation ill be honest.
Slumbering the stove for extended periods dreaming of overnight burns just to save a few seconds relighting in the morning and not sweeping the chimney regularly.
Also stuart read up on the scottish building regulations ( not the english ones that get quoted on here) there are subtle differences to what you can and cant do.
tonyf1Free MemberCertificate of Compliance http://www.hetas.co.uk/consumer/certificate-of-compliance/
yep know you can go via BC but takes forever and cost is high
Injury related to Carbon Monoxide
5thElefantFree MemberInjury related to Carbon Monoxide
Not one mention of log burners.
cozzFree Memberyou need really to have heatas certification if you ever sell the house, I also expect if your house burns down, insurance co will check for installation certification or not pay out
I’ve just had log burner installed
register plate added, chimney tested, co2 detector, soot door installed and logburner (I supplied) installed
cost £580 with certificate by heatas registered installer, fully compliant
some of you are paying over the odds !!
the heatas fitters are told NOT to sign off others work, as they become liable, its not worth the risk for them
EdukatorFree MemberDid the lot myself to local regs for about 1100e. My insurance costs me about 30e a year more as it wasn’t done by a registered professional.
MaryHingeFree MemberThis may help. http://www.stovefittersmanual.co.uk
I’ll be doing this in my new house in a month or so. Get building control to sign it off.
I will se if I can get a quote from a local Hetas fitter first. If there’s only a couple of hundred quid difference I’ll let them do it.
trail_ratFree Member“you need really to have heatas certification if you ever sell the house”
And this applys to scotland does it …. Strange how they never once brought it up when i bought my house…..
Or when my friend bought his house…..
chorltonFree MemberDid mine myself which included having to put in a concrete hearth at the base of the chimney. Cost me £240 to get building control to sign it off who were very helpful and came out quickly. Once when I’d fitted the liner and concreted the hearth and then once when I’d finished.
Would definitely use scaffolding if I were to do it again though.
I also used the Stove Fitters Manual.footflapsFull MemberI also expect if your house burns down, insurance co will check for installation certification or not pay out
If your house burns down I would expect any paperwork you had would be turned into ash…..
They normally turn up same day if you phone first thing, the way they work is pretty short notice, e.g. if you need footings inspected prior to concrete pour, you’re not going to wait 3 days. I’ve never waited more than a few hours for an inspection.
bedmakerFull MemberI know I need a liner and a flue pipe, at what point did you lot get the experts in?
I’m a HETAS reg fitter. I fairly regularly just do the reg plate, liner and connecting up of the stove. The customer will do the ‘building’ part themselves to save some cash. Digging out, lining the hole, hearth etc.
I can then check the work is all okay and give guidance on clearance to combustibles should they be planning a mantle/surround.HETAS in Scotland technically doesn’t apply but is coming in through the back door. It’s being demanded more and more by insurance companies, letting agencies, developers and even BC themselves are palming it off when there’s a stove in a new build. Good luck getting them to check anything. They appear to be well understaffed and the staff they do have are not exactly pushing themselves. (by their own admission I should add!)
Back on topic – don’t buy the cheapest liner you can find.
– Don’t be shy about asking to look at recent work the fitter has done, I’d be quite happy to do this. Most of the really, really bad work I’ve had to fix is not DIY but by ‘proper’ fitters.
– Burn dry wood
– Burn dry wood
– Get a moisture meter, check your wood is dry before burning.sharkbaitFree MemberTwo stoves here, freestanding one I did myself and had the inset fitted by a registered installer. Paid £1000 – £550 for the poujoulat liner and £450 for two people to install it.
“Certificate? No, it was installed before we moved here 15 years ago”
schrickvr6Free Memberdon’t buy the cheapest liner you can find.
How do you know what’s good and what’s not besides the different grades of alu?
gavtheoldskaterFree Memberi’ve done both the burners in my house myself, no liners. but then my father in law is a sweep so i know the chimneys are sound and the installation is good.
i have one burner in another place that we paid to have installed because we rent it out, and lets just say i went to a supposedly reputable and indeed large company, paid a lot of money, it was signed off, then had to get down to the threat of legal action to have the flue installed not only correctly but safely.
so if you do get a pro in, make sure you thoroughly inspect everything yourself.
schrickvr6Free MemberSorry on drunk holiday autopilot mode, different grades of stainless..
duckmanFull MemberHeras is coming next year. I would like to do as much as possible myself( ex plaster so hearth/fireplace etc all no worries. I don’t want to pay a fortune for jobs I can do myself, but if I get it done afore hetas I will obviously save on having to pay £500 to have something I will have taken a lot of care over rubber stamped.
tangFree MemberI have a strange one. Had 3 quotes for fitting, all Hetas. The first two said we need a liner. The last chap said no way do we and they were just trying it on. It’s a 1970s detached one off build, open living space on the 1st floor as we are on a valley. Who do I believe??
EdukatorFree MemberYou might not “need” a liner but your stove will draw better with one, the chimney will run hotter and need less cleaning, and you thus reduce the risk of chimney fire. Do you want a liner? Probably.
smartayFull MemberDepends if your staying put, HETAS certificate required and must comply with building regs which may flag up if selling in the future.
Breaking into chimney breast to make connections, be ready for a lot of mess 😀
Not sure where your based but in the NE wales area there was a guy going round purporting to be a registered installer which we nearly used, “No need for a liner”, when we spoke to our stove supplier he got straight onto trading standards!
timmerFree MemberTang, 2v1…… 1970’s house would have been built with a liner, probably clay, probably the worst material to build a chimney with. To conform to regs, no, you don’t “need” a liner, but you would probably want one if you want a problem free installation.
Ask the chap who said the others were trying it on if he has a digital flue draft meter and get him to explain the difference in readings from different chimney construction, including flexible liners with and without insulation.sharkbaitFree Member“No need for a liner”, when we spoke to our stove supplier he got straight onto trading standards!
You don’t ‘have to’ have a liner – its recommended but not a requirement.
smartayFull MemberAs stated above , our house 79/80 build class one flue with open fire with clay liners, when we tried installing the stainless steel, cant remember if 5 or 6″,liner it caught on the cement joints as we were pulling it through, had to break into chimney from outside to knock out restriction as it is we are detached, would be areal mess if semi with flue on the partition wall
As i said need to use people who know what they’re doingtommo999Free MemberI walked into our local shop, and asked the friendly guy there for some prices. Wowsers. Talk about overpriced. He reckoned for the double wall flue alone I’d be looking at £2k, plus the cost of the burner (cheapest in there was £800). This excluded fitting. I laughed and walked out.
Needless to say I’ll be doing this myself with the help of the father in law.brickwizardFree Member[/quote]
It’s easier to pull the liner up from the bottom….You think? Pull from top down every time
twinw4llFree MemberDon’t put the liner in upside down, bodge it builders favorite trick.
granny_ringFull MemberThe cost of materials out of our quote of £1100 would have been around £450-500, so if you’re prepared to do it yourself yes you would save a fair bit.
Having seen the guy standing on the chimney stack wrestling with the liner bouncing it down the chimney, I was happy to pay the extra.
Plus if you pay building control to sign it off the savings would be less.Having said that if we lived in a bungalow and wanted to fit a twinwall flue I would do it myself and get it signed off. Helped a mate do his and all was easy.
cookeaaFull MemberSorry to hijack but this thread got me looking again…
We’ve got a plastered over fireplace in our lounge at present with an intact chimney running right up through the centre of the house.
My Missus has said she wants it renovating and a “Fire” putting in, her idea of a Fire is one that runs on Gas or leccy with pretend fire, I grew up with a proper fire that me and my Dad put in (mostly my Dad TBH).
Unfortunately the SO is adamant that a wood/coal burning fire would kill our children to death…I’m really just not keen on increasing our gas or leccy bill just to have a pretend fire…
Anyway I went off reading the interwebs after seeing this thread and ended up looking at boiler stoves, which to me seem ideal.
It’s not an open fire so should help alay her fears a bit, but most importantly we could plumb a stove boiler into the houses Heating circuit apparently, and still have the wasteful (but convenient) Gas boiler (and even the barely ever used imersion heater in the tank upstairs should we ever really need it) so we are covered for many eventualities…
I’ve explained and proposed this to her, and didn’t get a total refusal to consider it…
By my count We’ve got seven Rads (of various sizes) around the house at present, one of which would need to be turned into a “Heatsink” rad for the Stove boiler (Either the kitchen or the lounge downstairs I reckon), quite how this all affects sizing the Stove/boiler I’m not sure yet, but other than that I can’t see too many major blockers… just yet.
Anyone running a Stove boiler? care to advise? pitfalls, ease of operation, maintainablilty, cost of installation (DIY or professional), etc?
trail_ratFree Memberare you running your stove almost every day almost all day …..
if not you will be heating alot of excess water(in the water jacket) everytime your boiler fires up — or every time you light your stove for the evening.
i looked into it – seemed like alot of hassle and expense if your not there to keep the stove running all winter.
how bigs your house ? my stove with the eco fan keeps my house more than warm enough.
The topic ‘Woodburnerists; how much did you do yourself/cost.’ is closed to new replies.
