Hi, Hetas or building control sign off is needed.
I have previously installed 2 in my old house including a fairly complicated through a ceiling and roof scenario so im ok with all of that.
The clay flue liner is rectangular all the way through so I wouldn’t (or extremely difficult) be able to use a flexi liner within that anyway.
My thoughts are to install a fully sealed baffle plate with the stove pipe entering as close as possible to the entrance of the clay liner.
Im after confirmation that as long as its air tight the liner will draw sufficiently to not require a direct connection to the stove pipe.
I can position the stove pipe more or less directly below the clay liner and the surrounding area can be filled to allow less space for gasses to collect etc…..
I will get building control sign off again as in my old house.
