Viewing 10 posts - 1 through 10 (of 10 total)
  • Wood for fencing – need treated or treat your own?
  • cynic-al
    As above, I am struggling to find brown treated timber for a fence in the required size (or anything even close).
    Is buying sawn timber then treating it yourself going to be durable enough?
    jam-bo
    Buy pressure treated timber and then stain it.
    cynic-al
    Why?
    Green -> brown is going to look duff (and not match the existing part of the fence)
    wwaswas
    Pressure treated will last years longer than anything where you’ve just painted a surface treatment on.
    jam-bo
    because pressure treating wood forces the preservative deep into the wood. painting a preservative on gets a few mm deep at best.
    paint the whole fence if you want it to match.
    scotlandthedave
    +1 – cut a pressure treated post across the section and see how deep the treatment goes compared to a surface stain. The base colour wont be noticable under a brown stain and even if it was i’d rather this than replacing the fence in a few years after it all rots through.
    cynic-al
    OK thanks all.
    EDIT Ooh a question: I will have to cut down 150mm to match the 125mm I have. I am thinking cut at an angle and keep that edge down-facing so water doesn’t sit on it.
    Is that better than a flat edge (not pressure treated) at the top?
    cynic-al
    Bump
    properbikeco
    just get 125mm… !!!
    if you are going to paint slop it with creosote and used engine oil
    will last for years that way
    chickenman
    Cut edges into a bucket with 1″ of preservative in the bottom. Leave for half an hour (will wick several inches up the wood).
The topic ‘Wood for fencing – need treated or treat your own?’ is closed to new replies.
