Taking your point on board shark bait, and apologies for thread hijack!
In a sense, you are correct, the original frame was built and raised in days when central heating did not exist. the build process took longer and the frame dried out at a much slower rate than those of today. This is essentially the key factor. A frame nowadays is built and raised and in very short order, it is closed up and the underfloor heating or radiators are installed and fired up to help the plaster dry quicker so the place can be occupied as soon as possible. This rapid heating causes the oak to dry at a rate that never used to happen.
As I said, it loses no structural integrity as a result of this, just a different aesthetic. If you would prefer an oak framed house not to have splits and 1/4″ shoulder joint gaps, then either leave it open to the elements for a few years or if you insist on central heating, don’t wind it up to the max for the first 5 years or so and wear extra clothing!!
