- This topic has 75 replies, 21 voices, and was last updated 8 years ago by dantsw13.
wood burning stoves & condensation
muddydwarfFree Member
Been thinking about a wood burner for a few yrs, and having some minor but annoying trouble with condensation in & around the fireplace where said burner would go.
Firstly, would opening up the chimney and fitting a stove help with the problem, and secondly any idea of costs?Ta.
dantsw13Full MemberCost – £2k fully fitted from an existing open fireplace/gas insert.
You would have thought the heat from a stove would dry out any walls!!!
muddydwarfFree MemberFireplace is semi open, in that the existing Victorian fireplace is already there, but has had the chimney blocked and solid shelving built into the alcove, and a gas fire fitted to the front. Doubt that would take much work to remove.
slowoldgitFree MemberIt may be old soot and salts attracting the condensation: consider having a chimney sweep in. My house is better for having a stove, I’m sure the dehumidifier doesn’t work as hard, and there’s more air circulation.
dantsw13Full MemberFrom removing the insert fireplace
To this
Was 2k supplied and fitted. Villager Flat C 5kw woodburner. Love it, as does the hound!
JunkyardFree MemberUsing a burner and dry heat that then escapes up your chimney will almost certainly make the damp issue better
Amazed at the price folk pay to have one fitted. Its not that hard to do tbh
globaltiFree MemberYes, a stove sucks massive volumes of stale damp air out of the house and the atmosphere will be warm and dry like never before.
matt_outandaboutFull MemberAmazed at the price folk pay to have one fitted. Its not that hard to do tbh
I agree.
Sadly you run into the whole building regs / competent persons shenanigans.
captainsasquatchFree MemberThe condensation is probably a result of the property not having any ventilation anyway, so opening up the chimney will help with that even without adding the burner (depending on where you live) add a bit of heat and Bob’s your Aunty’s live in lover..
muddydwarfFree Member£2K? That’s cheaper than I thought TBH. A 5KW stove would be about right I think, fireplace is 5ft high, 4ft across & about 2.5ft deep.
I’m getting fed up of the condensation issues so this sounds like an attractive fix.crankboyFree MemberOur jerry built damp flat roofed house is significantly warmer and dryer for having a wood burner installed cost approx £1500 . you need approx 4m2 of wood storage per year. We pay about 60 per m2 for seasoned wood.
Quality of life and air in house is much improved and you get to play with axes.dantsw13Full MemberThe Sovefitters Manual is a good website with lots of info about fitting wood burners.
B.A.NanaFree MemberIf you need to fit a flue, I used these for flue kit http://www.flexifluedirect.comprices seemed reasonable.
Like said, someone with DIY skills could do it. I’m paying someone to do it and £2k sounds about right. The guy was prepared to use ladders, but I’ve paid for scaffolding as I had other jobs to do on the house exterior and it’s a 3 level house, he was grateful for the scaffold as I don’t think he was particularly looking forward to using ladders.
So, for me
Scaffold £500
flue kit and new chimney pot £250
^fitting £300
work to create new fireplace £300
stove kit (pipe, plate, connector etc) £200
Stove (possibly ebay 2nd hand) £500
maybe new hearth stone £150
Total is over £2k but some is guesstimate and I’ve offset part of scaffold cost to other jobs, which means about £2k.muddydwarfFree MemberBeen for a quote today, went to a place called Ramsbottom Stoves, who gave me a rough (ie not looked at the job yet) quote of £2.5-3K.
They will give me a full quote next week but having googled them it seems some are unhappy with them.
Will obtain more quotes this week. That figure seems very high to me.mrbiker473Free MemberIts fairly simple to price the job up yourself as said above…
First thing to do would be to get the chimney swept, as it needs doing before fitting anything,by a sweep who is a member of the Guild of Master Sweeps or NACS and also Hetas registered as they will do a smoke test at the same time and tell you if its safe to use on their certificate of sweeping.
Ask them how many rod’s they used (then if it needs lining you can multiply that by £p/m yourself either 316 or 904 grade ).Then the cost after are easy to work out, cost of stove, closure/ regsiter plate kit, a meter of flue pipe, carbon monoxide alarm and a new hearth if needed. Add on a pot hanging cowl if it needs lining. Then as a guide expect £400/500max on top for labour and issue of a Hetas certificate.
SaxonRiderFull MemberMuddydwarf, the stove will certainly solve the issues you list, but it will also make your life better by a factor of at least 5. It sounds like you have already started to take the leap into stove ownership, but someone who did the same thing a few years back for some of the same reasons, I can tell you that you won’t regret it.
beefheartFree Member£2k seems like an astronomical sum to me too.
I did mine for less than a few hundred £ all in a few years ago- and it isn’t too difficult, and is immensely satisfying to do yourself.
And yes, of course it will help with condensation.
I only wish I could install one in my new flat- which u can’t… 🙁globaltiFree MemberBeen for a quote today, went to a place called Ramsbottom Stoves, who gave me a rough (ie not looked at the job yet) quote of £2.5-3K.
Will obtain more quotes this week. That figure seems very high to me.This company talked us into having a liner and insulation when actually we already had a class 1 flue. We naively beleived them. They poured the unused insulation into the drain at the end of the cul de sac, blocking it and infuriating our neighbour. The elderly “assistant” (may not be working for him any more) went into our garage and urinated into a plastic bin of my wife’s personal possessions. We saw him but didn’t realise what he had been doing until we discovered the sopping mess two weeks later.
Just saying, like.
muddydwarfFree MemberI’ve already booked a consultation with Ramsbottom Stoves, wish I’d googled them first now.
I found an old threw on here that gave a negative (to say the least) review of them, also mentioned Bill Taylor so I’ve contacted him for a price as well.
Any recommendations?
There is a gas fire that needs removing and a fireplace opening up, not something I really want to do myself if I’m honest.muddydwarfFree MemberHow easy are they to keep clean? How often does the flue need sweeping?
neilnevillFree MemberThat depends. Burn only very well seasoned wood, with adequate airflow, and unless your flue is a bit odd it will burn clean and the flue will get very little ash or creosote in it. I’d still say get a set of brushes and sweep it once a year though, stops any build up, and you’ll find out if you are doing something to cause more creosote, enabling you to tackle it.
JunkyardFree Memberthat if you burn properly then you should not need that much sweeping
the real risk is burning unseasoned woods and getting build up of resins in the chimney that can then burn
A liner will be worse as it is narrower so it will “fill up” more easily
My boat used to get a small sized pan full of ash each season though that was on for about 8 months of the year and burnt only coal
neilnevillFree MemberBut a smaller liner equates to faster flue gas flow and it gets out the top before it cools and allows the creosote to condense on it. That’s the theory at least. The liner does need to be large enough for adequate flow though, 5 inch is ok for smaller stoves up to about 5kW, some want 6″. The stove instructions will state the minimum flue size.
muddydwarfFree MemberCheers, sounds like its not too onerous to deal with then.
Those who have stoves, have you found they improve condensation problems around the whole house? Our problems are mainly around the gable end & fireplace anyway, as it is a solid wall & very cold to the touch.B.A.NanaFree Membermrbiker473 – Member
Ps look at my classifieds if you need 9m of flue linerYeah, unfortunately it was a few metres too short for me otherwise I would have. 🙂
JunkyardFree Memberit does because it is constantly on and it produces a dry heat
Its not a miracle cure as condensation is usually caused by a lack of air movement – again it helps with this*
I would not guarantee it will solve the issue but I would guarantee it will make it better
* mine is the kitchen which dog legs off the house and has no radiator in it where as with the burner i can keep the back room and the kitchen warm o I dont have the issues i used to have
muddydwarfFree MemberThe msim condensation problems are around the fireplace and gable end in the front room, if a burner stops me repeatedly cleaning & repainting the area then I’ll be happy.
B.A.NanaFree Memberas above, I guess getting your chimney, swept, tested and looked at is the first thing to do. I leapfrogged all that as I needed work doing on my chimney anyway incl a new chimney pot, so I had the flue put in as well, even if it didn’t need it. My BiL has done 3 and only needed a flue liner in one of them, so it’s by no means a given.
Luckily the chimney to my lounge (in my little house) is pretty straight, so I got a 6″ liner, the builder was talking about a 5″ liner if the chimney was doglegged (I’m only putting in a 5kw stove so 5″ liner would have been ok).Re your quote of £2.5-£3k, did this include a stove?
muddydwarfFree MemberYes, the “quote” was fully inclusive of stove, fittings, building work & removal of gas fire etc.
My chimney is straight as far as I can tell but its been closed off as long as ive known the house (bought from friends). Its a C19th building that was originally the blacksmiths workshop for the coach house, my garage/shed incorporates the original gateposts for the coachyard.
The fireplace was originally the forge so I suspect the flue is pretty wide.neilnevillFree Memberas mentioned above the stove fitters manual is very helpful. For costs there are a lot of variables, it might help to break it down.
Stove – anything from 500 quid to a couple of k
fitting – from zero to lots, depnds on chimney in place etc. think about liner, insulation, fitting, register plate, cowl. Parts alone to line a ‘standard’ chimney would be around 500 quid
fireplace – hearth, mantel, surround etc all fancy will cost a couple of k, a simple mantel of chunky oak is a lot less clearly
wood store – do you need something? you can do fine with a couple of pallets and a tarp but may decide you want/need more
wood processing, are you going to buy seasoned logs or scrounging and processing? if the later then chainsaw and ppe, maul sledge and wedges costs about £350
JunkyardFree MemberFWIW if you buy second hand in summer you get very good prices on ebay
I got a 1 k stove for £130 – granted its about 20 years old now but they dont exactly wear out – grate aside though mine was fine.
I am not sure what the advantage is in getting one new as they dont have move parts or wear out.
Be aware of outputs as a large output means a large fire and that means eats more fuel
I made a smaller fire box for mine with fire bricks – its a big fireplace and a small stove looked silly but it is a bit bick [ heat output ] for my needs
mrbiker473Free MemberThe fireplace was originally the forge so I suspect the flue is pretty wide.
They probably will suggest a flue liner for that then, and it will work better with one.
Also if you have problems with condensation/water around the chimney, make sure the stack and chimney are sound so water can’t get in too easily. And that they use a good amount of vermiculite to insulate the liner and stop it rotting away within a few years.
neilnevillFree Memberif buying used on ebay there are some deals. They don’t ‘wear out’ but can be damaged through over firing (so look out for warped plates and cracks), or using wet wood causing creosote and corrosion. that sort of damage is costly. cracked baffles, grates and firebricks also happen but are easier to replace.
oh and one other thing, over 5kW the stove requires an airbrick into the room in which it is installed to meet hetas.
JunkyardFree MemberThey probably will suggest a flue liner for that then, and it will work better with one.
They will as they all seem to suggest it but the fireplace was built for a fire so why would you need one?
A non leaking chimney built for an open fire will be , generally though test it, fine with a fire.
muddydwarfFree MemberThe room is fairly small – old house – so 5kw will be more than enough, we don’t want to be sat against the back wall in our underwear!
This is why I’m getting pro’s in, I’ve no idea about building etc.
As long as the stove has a big enough top plate for a coffee pot or a casserole dish I’m happy.mrbiker473Free MemberThey will as they all seem to suggest it but the fireplace was built for a fire so why would you need one?
A lot seem to do yes, and in a lot of cases don’t need them such as a “standard semi detached houses”. But for overly wide chimneys which this sounds it is, it would work better as the chimney was designed for a large fire at the bottom, where as a stove would give out less heat up the chimney. So you’d get into the issue of a cold chimney and when the fumes hit it Condensing and forming creosote and soot.
Also if it is wide you’d need more heat in the flue to get the gasses going up and out the pot, and not lingering around the register plate at the bottom where it can collect and seap into the room/ cause a fire with fallen soot or creosote on the chimney.
That’s still depending on how wide the actual chimney is once opened up as well.
ghostlymachineFree MemberCos the chminey was sized for a raging inferno kicking of many many m3 of smoke and combustion products. A 5kW domestic stove doesn’t.
Much like my mate who lives in the old bakery. Loads of issues with his until they came round and fixed it. By clipping 2 or 3 liners (one for each stove) to the inside and backfilling the rest. Chimney took about half a day to sweep before they could start working on it.
Now takes 20 minutes to do all three. Much like ours, guy turns up, sweeps chmineys, cup of coffee and on his way, all before his van has even had time to cool down.
ghostlymachineFree Memberdammit, beaten by 7 seconds.
And OP, get a stove fan, open the doors up and it’ll blow hot air round the whole floor.
The topic ‘wood burning stoves & condensation’ is closed to new replies.
