After years of sticking fingers in ears and going “LaLaLa can’t hear you”, I’ve decided to take up my father’s offer of a spare wood burner they’ve had kicking around.
Trouble is, our 20 yo house doesn’t have a chimney breast, so we intend to remove the existing gas fire and supply (using a gas fitter), and install an insulated stainless steel flue using the hole in the wall used by the gas fire vent.
Phoned Building Regs to check out what I needed to comply with, and the guy wouldn’t tell me!
“Use a professional installer” was his response 🙁
The only “helpful” advice was to give the name of a business that could do the work. Not quite sure what to make of his advice TBH
Help required from the STW Hive…!?
So – flue, hearth stone / slab, ventilation?
Any info of references much appreciated
