2007 women's Stumpjumper FSR frame in medium. A few scuffs, chips and scrapes; but nothing worth a particular mention. The frame has had one owner from new in late 2007 and has had a relatively easy life at the hands/feet of my partner. No drops; no jumps; no shredding of gnar...
The Fox Triad (ProPedal, Lockout) was serviced by TF Tuned in early 2010 and has probably only been out for around half a dozen rides since as her P7 got the most trail time (and hence the sale). Perfect working order and absolutely no wear to the anodising. The shock has been protected by either the Spec' mudguard or, more typically, an inner tube guard between the seat post and the seat stay.
The suspension bearings (complete set from Specialized) were replaced around the same time. Either way, neither are going to need attention this year (unless you wreck them yourself, or course).
The BB threads are immaculate and have been cleaned. No stripped or messy threads. The brake spots have been faced.
Included in the sale will be two mech hangers - one brand new, one used but straight (removed prior to shipping). There a Hope bolt-up seat clamp and a generic QR clamp; the Specialized FSR neoprene stay protector and the FSR mudflap. There will not be a headset fitted to the frame - the one in the picture has been removed.
As I said, no marks worth mentioning and certainly no cracks or dents.
The frame weighs 6.01 lbs by my Park Tool scales.
Asking price is £320, which includes £20 for tracked/insured delivery.
I can supply more pictures if required.
26" QR wheelset. DT Swiss EX 5.10 on NukeProof 6-bolt 135mm/10mm QR rear (2.06 lbs); DT Swiss X430 on Specialized Stout 6-bolt QR front (1.15 lbs).
Both wheels in excellent condition - true and no flat spots. Both hubs use cartridge bearing and are running smooth.
£140 shipped.
26" Specialized/Alex Rims 10mm bolt-up rear (3.02 lbs); 20mm thru-axle front (2.08 lbs) wheelset. These wheels came on a new bike (Big Hit) in 2007 and only had a couple of rides while I had another set built. One or the other has been put to use on occasions since then, but they have really seen very little use and have spent most of their time on the shelf (hence the dust coating they have!). Both rims are in very good cosmetic condition.
The front runs true and has no flat spots. The rear has no flat spots but does have a little wobble which can be fixed by truing - the rim is not damaged/warped.
Both hubs are for 6-bolt rotors and use cartridge bearings, all of which are running smoothly, which is no surprise given how little use they've had.
The axle on the rear hub is a solid 10mm version which uses track nuts. It is unusually long on the drive side as it was designed to be used with Specialized's derailleur protector. It's no problem to use it as it is.
A decent heavy duty wheelset for big bikes, or as a burly second set for uplift days!
£100 shipped.
Gamut G45 chain device good for 36T to 40T chainring. BB mounted backplate. Bash is in great condition; the lower roller has seen better days. It spins freely, a bit too freely, and has the occasional notch. It's not seizing, so it still does what it's meant to do, but I have to mention it. Everything else is great, including the top guide, so even if the roller needs replacing at the end of the year there's still a bargain to be had.
£35 shipped.
Race Face Diabolus crank arms 170mm. Used, but not abused. There's heel rub on both arms and a few scuffs here and there, but they're in great working order. The granny ring tabs have been ground off for chainguide clearance, so the cranks are only good for a single ring in the middle position. Pedal inserts/threads are all good, as as the axle threads. There is a selection of the adjustment spacers included.
£45 shipped.
Shimano XT M760 9-speed shifter There are a few small marks here and there, but overall the condition is excellent. The selector window is as-new, having been removed from the shifter before it was fitted. Perfect working order.
£20 shipped.
