- This topic has 271 replies, 66 voices, and was last updated 10 years ago by Yetiman.
Wolf Tooth Components. XX1 type chainring
mosFull Member
I just got one of the X-Type Snowflake ones delivered.
IMG_2077 by marcusandcath, on FlickrHowever, after closer inspection, it seems that it has a completely different offset to the middleburn x-type ring, which makes me think that they’ve got their sums wrong. Pic below of old next to new.
IMG_2171 by marcusandcath, on FlickrWhich is further exacerbated by the ring being 2mm thicker at the spider, meaning that the space between the ring & the LH crank is narrower then the BB shell & bearings.
GaryLakeFree Membertehan: who would be best to contact regarding reviews? I’m currently writing up Hope’s IBR but quite keen to cover a SRAM Spiderless option… email in profile.
HolyzeusFree MemberOrdered my 30T from Wolf Tooth two days ago, it was shipped last night! 8)
coursemyhorseFree MemberInteresting thread. I’ve been looking for one of these too and there seem to be a few options now. Someone said RaceFace have some? Details? I tried contacting works components as they are UK based but they have not replied to me. NSB, Raceface, Wolftooth, Absolute black, MRP? all do them? Are they all pretty much doing the same job and have similar tooth profile and design, or are they likely to be different and perform different to each other do people think?
I like the idea of an integrated bash guard on the wolftooth, but dislike that they made it a bespoke BCD to only fit their stuff. It would be good to see 104 BCD mount holes on a SRAM direct mount chain ring purely to mount a bash guide to, but I’m not sure I really need a bash.barbsFree MemberRace Face Narrow Wide chainrings now up on Wiggle, end June apparently.
chiefgrooveguruFull MemberI received my Works Components 34t a few days ago – looks good, waiting to get my broken cranks off (bloody silly Truvativ (non-)self-extracting design) so I can try it out…
singlespeedstuFull MemberI like the idea of an integrated bash guard on the wolftooth
The Wolftooth doesn’t have an integrated bash.
Done quite a few rides on mine now including the Dyfi enduro and it’s been faultless.
crankriderFree MemberReceived my Works one too – again looks rather good and has worked fine so far 🙂
I can see the other immediate player being Raceface @£40.00 and £45.00, wiggle are already discounting 10% as expected 🙂
The wolf tooth is too much money and cba to order a chainring from the USA – too much hassle. E13 will no doubt be on price-point too, Works still cheapest at £35.00 and for a consubable item that wins me over.
uselesshippyFree MemberMy works one has just turned up.
I’ll fit it tonight, and let you know how it is after it stops raining. 😀NorthwindFull MemberGot my Works one on and took it out for a spin sans chain device on tuesday- no fuss at all. Possibly a wee bit more drivetrain noise than usual? But zero drops. It wasn’t the harshest test but it’s a good start, will try and give it a proper rattle next week.
I’ve ridden this same bike with the clutch mech, E13 singlespeed ring, and no device before and it didn’t really work at all so it’s definitely an improvement. Yet to find out if it’s enough.
coursemyhorseFree MemberI tried emailing Works components twice and no response. If I click through to the webpage to order a 32, it says out of stock but it looks like I can still add to basket and checkout. Advice?
svalgisFree MemberThe Wolftooth doesn’t have an integrated bash.
They’re probably referring to this.
coursemyhorseFree MemberYes I was refering to that but:
a) It’s a bespoke WolfTooth fitment and locks you into an indy outfit based in the USA.
b) It’s $47 for something that may breakI would pay £35 for the works one in the UK right now, or as said above, RaceFace have now appeared on Wiggle available end of June @ £40. the RaceFace ones look like they have a nice engraved logo on them.
tehanFree MemberProblem with RaceFace is that it may not work properly. Please don’t jump on me as i do absoluteBlack rings and am their competition, but to be perfectly honest thick-thin profile does NOT solve the problem. It’s a tooth profile that plays major role in that. They are wider, more square and a tiny bit taller. Tolerances are also smaller that means chain will almost not move back-forth on the chainring when fiddling with fingers.
If you look now at RF and E13 offerings they only added thick tooths to the already existing design. That means it will not work like it should in my opinion as i already done that long time ago and know the outcome. Thus completely different tooth profile on my side.
time will tell. Please note that on their site is no word that chainkeeper is not necessary, only this: “Now with performance enhancing chain retention technology” which means it retain bit better which is true some way, but will it allow you to drop the chainkeeper off of your bike?:)
this is my personal opinion and i am not trying to convince anyone. Just show you a point of view of someone who done some work in that topic.
tehanFree Memberforgot about other side of the story.
Thick tooths do wear out quite quickly – especially during weather like we have today in UK:) When chainring is new there has to be already small play between plates and thick tooth. But after a month in the mud this play is around 0.1mm bigger. That means thick tooth does not hold chain at all at this point as there is a fair distance from both sides to the chain plates. So the only thing which help to keep things still on place is that square-ish tooth profile.
But that will not last forever as well. Sram admits that also.svalgisFree MemberSo unless you want to replace your chainring every few months you’ll still need a chainguide. Oh well.
coursemyhorseFree MemberSo unless you want to replace your chainring every few months you’ll still need a chainguide. Oh well.
What does this mean? It reads to me that you are saying that there is some kind of correlation between wear rate and requriing a chain guide. Please explain.
I think that Tehan, you as a manufacturer of your own chainring are entitled to your opinion and to talk up your product. To me though, I would think that they are all very similar in performance if they have basically used SRAM XX1 as a guide to how to achieve better chain retention. Otherwise why bring one out at all. We have enough chain rings on the market that are considered “normal” chain rings. It will become obvious as more get out into the wild as to which ones are sub standard if at all.
svalgisFree MemberWhat does this mean? It reads to me that you are saying that there is some kind of correlation between wear rate and requriing a chain guide. Please explain.
tehan explained it in last post of the previous page. Long time reports from XX1 owners seem to indicate the same thing.
crankriderFree MemberTehan in own product big up shocker.
Tbh rings don’t last forever anyway do they, run them with a top only guide and be happy 🙂
I am sure xx1 users have been on them longer than a month with no issues?
crankriderFree MemberOh and of course, the key is that the works and Rf rings are as cheap as standard rings, so what is the point in not buying them over a normal ring? Makes no sense!
I can honestly see every ring manufacturer moving to it… Any benefit is a selling point after all?
I still want x9 11spd to happen, then I will be happy!
svalgisFree MemberTbh rings don’t last forever anyway do they, run them with a top only guide and be happy
That’s exactly what I’m doing. I didn’t mean to sound negative – I was myself dead set on ditching chainguides altogether but I decided to go for a top only guide just to avoid any potential problems once the ring wears down. I now run a Wolftooth spiderless with a Superstar top guide and it works well, even without a clutch mech. Maybe I would have just as much luck with a regular SS chainring (bling ring in my case), but there’s not much in it price wise so why not.
I’d probably give it a go without a guide if I was still on a hardtail, considering that I ran my Soul with a regular SS chainring and only very rarely dropped the chain (clutch mech essential in that case).
tehanFree MemberOk so once again.
IF chainring does not have a special tooth shape(profile) it will not work good without chainguide (even if it has thick-thin profile). So RF or E13 will require something to hold the chain on top. As i said time will tell when people start using that. I went that way on the beginning of my development and i know what’s the score. Big companies add thick tooths as everyone expect that to happen. But unfortunately it looks like afterthought as tooth profile is not changing – that is really critical to that system.XX1 rings- as someone already said long term tests already show that chainrings don’t hold chain as when new after XXX miles. This is normal. There is no miracles as if chainring wears out the tolerances are bigger.
What distinguish XX1 or my rings from others is the tooth profile- this does not wear out as quick as thick tooths. So it means it will hold chain much longer than other chainrings. Simple as that.this is a video of my ring to let you know how good they are:
https://www.youtube.com/watch?featur…&v=FQ19arAErsY
Rider – Marek Konwa. Silver MTB World Champion, National MTB Champion, CX National Champion and so on. It’s his personal video, so not moded by me etc.uselesshippyFree MemberFirst ride today on my works componants ring, around the roughest trails tunnel hill has to offer. 😀
I deliberately ran it down the rougher stuff in a higher gear, with the pro_pedal on, throwing the bike about a bit, and the chain didn’t budge.
Took half a lb of weight off losing the chain device, less noise, and a little less drag. At 35 quid, I can’t fault it.
I’d still like the stupid low gears mrtee has though…. 😀tehanFree MemberThis is to show you how good retention this chainring has. It’s all about the tooth shape which can keep the chain in place. Only 5 links is enough to hold more than 2 pounds (in fact you can hang much more. Regular chainrings require at least double that.
Try to do it with yours and see result.
This is not glued, tied or anything else. Chain just meshes perfectly with chainring and will not come off that way.
[IMG]http://gp1.pinkbike.org/p4pb9627092/p4pb9627092.jpg[/IMG]
MackemFull MemberJust back from a proper ride using the Wolftooth chainring (30T) not a single dropped chain. Some pretty bumpy, rocky stuff, finishing with a downhill track. (Admittedly I minced down that, but I’m on a hardtail).
No. chain devices or owt.
MrGFisherFree MemberTehan, do you have 32T black SRAM spiderless rings in stock now?
njee20Free MemberCan you stop spamming the forum now Tehan!
We get that yours is the best and everyone else’s product you’ve not tried is rubbish, but I’m interested in first hand opinions of all the different options, not bloody adverts of yours!
tehanFree Memberi have never said that someone else’s is rubbish. If you got such impression then i am really sorry njee20. I will not post more about it unless someone asks me. Is that ok with you? If you want to test it yourself email me.
MrGFisher- Wednesday in as i just posted last one on sat.
STATOFree MemberTehan, the problem i cant get out of my head with your ring is chainsuck. When the ring is a little worn wont the taller teeth just hold the chain? How does it fare in gritty mud?
NorthwindFull MemberYeah, I was wondering about that too. Also, does it keep that performance when worn? If it’s all about the clever tooth profile does that hold up over time?
Might need to give one a crack next time I need a ring to compare.
STATOFree MemberYeah, I was wondering about that too. Also, does it keep that performance when worn? If it’s all about the clever tooth profile does that hold up over time?
He does say on website works better worn than xx1 style, id just like to know what exactly it is that helps, dont doubt just curious and id want a little more explanation before spending that amount of cash.
somafunkFull Memberdo you intend to make middleburn x-type UNO rings?
I asked matthew at middleburn the same question last week, they’re in development at the moment and he said to keep an eye on facebook for details.
tehanFree Memberhi guys, i start being more busy than i thought so not much time to read that all, all the time. If i miss something important just write me an emial and i will answer so someone can writie it here is necessary.
But to answer few questions.
There is no chainsuck. Believe me or not but chain goes on that chainring as on any other one (almost) – it’s almost ideally calculated so it fits like a glove on hand if you know what i mean. So it meshes like it really should. On some new chains(kmc and xx1 as i know for now) i found that sometimes there is a need of 20miles “bedding in time”. That means chainring is a touch more louder than normal. But after that it’s all good and silent like on a regular chainring.Mud – tooths does not wear out down. I mean recesses between tooths almost does not deepen in time. What wears out most is the right hand side of each tooth profile if you look at the crank from the front. But what really helps to keep chain from coming off is the right hand side of that tooth. I can’t write more:)
What you have to understand is that thick-thin profile will wear out in mud quickly (in dry a lot longer) and will not hold the chain good anymore (my tester is sponsored by Sram as well and he already has to use chainkeeper on World cup races with XX1 ring after two months in mixed conditions – check marek konwa facebook page). Once that is worn(thinner) and you have regular tooth profile like RF there is absolutely nothing which helps to keep the chain on.Honestly – no one will be able to make chainring which will keep chain forever. It is not possible and customers need to know that. XX1 dies in two months in hands of a pro rider in any possible condition (UK mud included). Mine will hold same distance from tests we have made, but you get it chaper. I have few amatour testers as well doing bike marathons and they are still happy after 4.5 months with chain retention.
What really matter in era of such chainrings is the question “how long” not “if”. So designing it as best as it could be done let you to use it a bit longer.
If you guys doing really big stuff, the the longer you use the chainring (mine or xx1 or other) you will eventually drop the chain. Next year this time it will be obvious when there will be enough people using it.
uff. thanks.tehanFree MemberNo middleburn x-type UNO rings – sorry. The offset is huge as far as i remember so i would have to use really thick sheets to mill that. I think they use a press to make a dish and that is far too much complications for me to make one ring.
hope you understand.
The topic ‘Wolf Tooth Components. XX1 type chainring’ is closed to new replies.
