It maybe because you have too much "rubbish" being loaded in the background.
Click on the start menu, click Run,then type in "msconfig".
This will bring up a window. Click on the start up tab, this will show all of the stuff that windows loads in the background. For instance Adobe Acrobat viewer kindly installs a widget that makes sure you have the latest version, you don't really need this.
Uncheck the items that are slowing your PC down, you may need to perform a little trial and error here. You could also do the same with the Services tab.
You do need to be careful as you could stop something loading like your anti-virus from loading.
