As above ^^^^^^
Plus a rough guess, I would suspect line fault still, is a guess in the absence of not being there in person to test. I’d normally try and use my own laptop plugged into the router to rule out the PC.
Main reasons used to be:
i) lots of upload flooding the bandwidth, if you use all your 1Mbps upload you will get nada on the download.
ii) really bad errors on the line so every bit of information is having to be reattempted until it downloads succesfully.
iii) Downloading too much – you said new PC. Probably not an issue after a few hours, but check Windows Update isn’t downloading.
Given most parents use of the internet I would guess the errors thing.
For a BT line if you can get some web access try here and follow the instructions – don’t be tempted to miss bits:
http://www.speedtest.btwholesale.com/
