• This topic is empty.
Viewing 1 post (of 1 total)
  • wigan / haigh hall heads up
  • oreetmon
    just got back from a quick blast, looks like john rambos been up to his old tricks. little jumps and drops near the top had 2″ thick branches stuck in the ground, sharpened at head height and the culprit has now started to zip tie 1″ thick branches across the trails around blind corners and quick runs ,,,, tried to bulldoze through one and ended up on my erse.
    dismantled all the traps i came across but its a big place so thought it worth a mention.
    was injured with fishing wire a couple of years ago and let the local media know, will be reporting to paper AND police this time. would be use full if others did the same.
    cheers.
The topic ‘wigan / haigh hall heads up’ is closed to new replies.
