Could be a lot worse, at least no monay has been wasted on non-functionning, massively heavy suspension. Probably is better out there although I was amazed recently when I found out how expensive a 'reasonably' specced rigid hybrid was.
This seller sells subway, fury frames etc… you have to be quick when they're up though! I built up a mtb using a frame off of him for around £200 for my wife, that was with discs and suspension so I'm guessing you should be able to come in lower than the £185??
You realise that if she buys it, you'll have to touch it at some time. I'm pretty certain that i'm allergic to chrome plated steel, but you may not be so lucky 🙂
