A quote from On-one regarding their 810mm bars.
If your riding involves a bit more full-throttle speed – and full tilt technicality – then you’ll really benefit from running a wide set of bars.
Sure, you’ll whack a pinkie finger every Preston Guild but that’s a price well worth paying for the benefits of big bars.
More stability. More room for a bit of the ol’ Body English. Better cornering. Oh Lord, such better cornering. You genuinely become a better rider, having more fun, when you slap on a pair of wide bars.
Honestly, all it takes is one brakes-off hooning drift around a slingshot corner to convince you that wide bars are unassailably awesome.
Sounds intriguing, so what’s the truth if any behind this?
I run 680mm now and wondering if a step up to 750mm would help. This is for my full bouncer which I use mainly for trail centre hooning with an aspiration toward what might be coined freeride.
So my questions are:
1) Is the above statement in any way justified?
2) Am I likely to benefit from a 70mm increase, or should I maybe go wider?
