Obviously there’s no cable to get kinked on a Reverb. Possibly you could crimp the hydraulic hose but you’d know you’d done that, and you’d probably see evidence of blown out seals at the bottom end, too.
If you’ve had the post out of the frame to get at the air valve and the post now mysteriously fordnt extend, my money is on the seat collar being too tight. Undo it so the post is loose in the frame then try the button again. If it works now, then happy days and don’t rag the collar so tight. If you still have an issue then it’s the equivalent of stuck down shock. I forget which way round it works, but you’d need to let the air out with the post at one end or the other of its travel then refill then rebleed.
