Viewing 19 posts - 1 through 19 (of 19 total)
  • Why is my new mary as slack as a retired porn star?
  • tpbiker
    Following my what front tyre thread I sourced myself a magic mary snakeskin tubeless easy..
    I’ve fitted a good few tubeless tyres in my time, and my Exp with schwalbe on the Mtb has been good. So armed with my new airshot I was almost looking forward to the task..
    Anyhow.. Tried it with the core out, no success.. Tried it with soapy water.. No success.. Fitted tube overnight and tried again.. It’s not even coming close to seating..
    One thing I did notice was how ridiculous easy the tyre was to get on the rim…fitted by hand in about 2 seconds without the usual faff of trying to position the bead in the rim channel etc etc.
    The rims are tubeless compatible and nd I’ve just take off a nobby nic that went up first time so it’s not them..so is my tyre a dud?
    Ps.. No it’s not a 29er tyre on a 650 rim.. I checked.
    frankconway
    Surely you mean loose – not slack?
    tpbiker
    Well either could apply surely?
    RobHilton
    [video]https://youtu.be/QgmyVLheqkQ[/video]
    Tom_W1987
    Could be a QC issue I guess.
    davosaurusrex
    Mine was/is the same, extra layer of tape sorted it
    benpinnick
    Because Schwalbe tyre diameter is a lottery, thats why.
    bigblackshed
    Moar tape.
    matt_outandabout
    [video]http://youtu.be/QMvE0yFnR0I[/video]
    johnw1984
    Don’t even get me started…
    Ben earned £200 off me for some new wheels I was that fed up 🙂
    tpbiker
    More tape it is then. Reluctant to take it back as I couldn’t find one online anywhere..then saw one left in decathlon of all places.. while buying socks..
    bigfoot
    only tyre i’ve ever stuggled to seat even with a small compressor, ussually takes about 5/10 minutes of messing with it to get it on.
    tdog
    So let me understand your point correctly, you’re stating on the internet for all to listen that ypu have slack rubber.
    At a guess, I’d say you were unlucky in the trouser dept. Either that or Durex suddenly made extra large condoms, which I doubt, which is why… 😛
    pdw
    Have you tried manually seating it with a tyre lever? i.e. Using a lever to lift the bead out of the channel and onto the shoulder all the way round?
    frankconway
    Would Mary approve of you using a tyre lever on her?
    tdog
    Yeah like wouldn’t it take more than one lever to get Mary to squirt stans all over you
    lornholio
    I remounted an old Snakeskin Magic Mary this week, pretty loose indeed. I normally use a petrol station compressor or a friend’s homemade bottle inflator but got it up fine this time with a track pump and valve core removed after wrapping a 26″ tube around the outer circumference of the tyre and pulling the bead into place.
    tpbiker
    How do you do this? I’m not following !?
    whitestone
    The problem is getting enough air quickly enough into the tyre to force the beads to seat in the rim. By wrapping an inner tube on the outside of the tyre you are reducing the volume of the tyre so you’ve a better chance of popping the beads into place. I’ve done similar by simply wrapping my arms around the wheel and tyre and then triggering an airshot.
The topic ‘Why is my new mary as slack as a retired porn star?’ is closed to new replies.
