Viewing 22 posts - 1 through 22 (of 22 total)
  • Why does my road bike transmission still skip?!?
  • SaxonRider
    I have changed my cassette and chain, as well as having had two different LBSes do the indexing, but the chain would still skip when on the fifth sprocket (working up from the smallest).
    I have since changed the large chainring to a new one, and thought that that would solve the problem. But no. On yesterday’s ride (the first in a few weeks), much to my frustration, the skipping was just as bad. And always on the same sprocket.
    What’s up with that? How the &*!$ can I get the transmission working smoothly?!? 👿
    scotroutes
    Possibly a bent mech hanger. Have you had it checked?
    Always worth fitting new cables too.
    SaxonRider
    The mech hanger is brand new, and I think (I’ll check) that the cables are as well…
    scotroutes
    Check the mech hanger anyway. I’ve had to straighten new ones….
    therevokid
    jockey wheels?
    jabbi
    +1 mech hanger or maybe a bent tooth on the sprocket?
    xyeti
    I’ve recently been trying to eliminate similar but it wasn’t dropping down to the smaller cogs from the middle, i’ve just fitted some new Jagwire cables and it shifts like clockwork now, Yours could be any of the above though, Jockey wheels, bent tooth on the sprocket????.
    wilburt
    Bought a hanger straightner from wiggle, should have bought one years ago.
    TiRed
    friction in the cable outer on the last before the RD? Does it index really cleanly to and from this sprocket? I replace mine at the slightest hint of poor shifting and skipping. Otherwise hanger alignment.
    handybendyhendo
    Loose free hub / wheel bearing……
    bigblackshed
    Buy one of these:
    You won’t regret it.
    Onzadog
    Could be a frayed cable snagging in the shifter but my first thought was mech hanger.
    buckster
    Might be a stiff link in the chain when it was joined
    blader1611
    Wouldnt a bent hanger affect more than one gear? OP says its always the same gear and bent hangers in the past for me have affected more than one gear. Have a look at that sprocket for any teeth with a burr on it, i had a new one which had a couple burrs on the teeth and that took me bloody ages to find. Good luck OP
    FuzzyWuzzy
    I’ve seen a stiff link and dirty cables cause skipping on otherwise new transmissions
    martinxyz
    Single sprocket fitted the wrong way around?
    jobless
    limit screws.
    that can have a massive effect on shifting performance because if you have the limit too tight on the higher gears as it moves through the block the tolerances go out of whack and eventually you get the skipping.
    parktools.com has a step by step guide on how to set it up. just follow that. its 5 minute job. you would be surprised at how many bike shops cannot do this properly.
    pdw
    How do the limit screws affect anything other than top and bottom gears?
    pdw
    OP – is it slipping or skipping? i.e. do the pedals jump forwards under load because it’s skipping over teeth, or is the chain trying to drop or climb into the next gear?
    Will it do it on the workstand, or just when riding?
    trail_rat
    limit screws.
    no they cant.
    simons_nicolai-uk
    limit screws.
    The limit’s just a hard stop though isn’t it? Too much cable tension against the limit would do this but then you’d not get into the second gear.
    (have been having a similar problem with my own road bike)
    MikeWW
    Stiff/bent link
    b screw adjustment
    indexing
The topic ‘Why does my road bike transmission still skip?!?’ is closed to new replies.
