Sometimes the hills get very steep and you need even more power than sitting allows. Here, the danger of losing energy to the bottom of the down stroke is greater. But with some generous body English, you can make the bike work for you.
If you’ve ever been on a ski machine or elliptical trainer in a gym, then you’ve actually used a technique that helps with a standing climb. As the ski machine makes its oval-shaped revolutions, you weight and unweight your feet, keeping your body over the weighted foot. If you pay close attention, you’ll find that your hips and shoulders move side to side just a bit to give the downstroking leg more power.
Now imagine that same motion on a bike. That side-to-side motion has to be more pronounced to obtain a full revolution of the pedal. Unfortunately, this means that your body has to move side-to-side in great energy-wasting motions. So don’t move your body—move your bike.
As you begin the downward stroke, lean the bike away from the foot delivering the stroke. Keep your body in a straight line over the weighted foot. Lean forward on the handlebars to deliver even more power, but keep your elbows loose. As the weighted foot finishes its stroke, transfer your weight to the other foot. Use the bike as a lever to help pull your weight over to the other foot. The bike should now be leaning toward the unweighted foot and your body should be in a straight line above the weighted foot.
Pay very close attention to your pedaling technique. Really think about moving the foot back as if you’re scraping your shoe. Then pull up on the pedal and step forward until that foot is ready to deliver another stroke.
Practice: Pedal with just one foot and try to get the push-scrape-pull-step motion down so that you’re delivering a smooth circle full of power. Do this a hundred times. Now do it with the other leg. Once you feel comfortable doing this with each leg individually, start using them both to climb that hill.
