- This topic has 150 replies, 42 voices, and was last updated 8 years ago by njee20.
Why arent all road pros on aeto bikes?
mrblobbyFree Member
Blimey, big hitter consensus! Can’t happen too often on here 🙂
aracerFree MemberI’m suggesting that a diamond frame made out of solid tubes has so little vertical compliance that it’s impossible to tell the difference given compliance in tyres and saddle. Though I have to admit I was being a bit hasty, as there’s also compliance in the seatpost and the Tarmac has a long enough one of those that it might make a difference. Bolt a non-aero seatpost on a Venge and you’d find it just as comfy.
njee20Free MemberRight. So they’re all the same? BSO to R5Ca? As long as you have the same tyres, saddle and seatpost?
Ti, steel, alu, carbon?
Solves that long running debate anyway!
DanWFree Membergod knows why felt use that hideous 12k carbon look
The same marketing department that fail to properly advertise how aero their aero bike supposedly is also seem to be failing to tell the engineers what look is so in this season 😀
eshershoreFree MemberIt’s an interesting question, “why-arent-all-road-pros-on-aero-bikes”?
I’ve been lucky enough for the past year to have access to Giant Defy Advanced Pro, Giant Propel Advanced Pro and Giant TCR Advanced Pro bikes and easily chop and change between them.
It’s been an interesting experience for sure, and gave me a real insight into the differences between an endurance bike (Defy), aero race bike (Propel) and race bike (TCR). They all have very different handling / feel and advantages / disadvantages.
I was also riding this last week, the 2016 TCR which was quite a revelation compared to the older TCR – the old TCR felt very “neutral” whilst the new one feels “lively”
The Propel is very different compared to other aero bikes I’ve ridden in that it was surprisingly comfortable and had very balanced handling. I also preferred the slightly taller head tube of the Propel to the TCR, which I almost found too aggressive in terms of reach and drop.
However, a smaller rider can have issues getting an aggressive drop on the Propel advanced pro models with their OD2 steerer / stem due to a lack of aftermarket stem beyond 8/10 +/- degrees; and this can negate the aero advantage
The Giant Alcepin team riders can’t ride the current Defy as the UCI have not ratified the rules on disc brakes, so were riding the previous season Defy in the classics during 2015.
when we met the Giant Shimano Team (as they were then known in 2014) in London last year during the Tour De France, I asked several riders including Kittel about their bike choices, and they said it was personal preference, they had access to all the bikes.
Most preferred the TCR for its efficiency, with Kittel choosing the Propel for its pure speed advantages during sprint finishes.
Something I have found with the aero bikes is the bike really gains benefit from also running deeper section wheels, which then have the disadvantage of extra weight, flex under power and nervous handling in high wind conditions.
I tried taking the aero wheels off the Propel and fitting low profile climbing wheels, and a very noticeable difference in having to work harder to hold high speed on the flat compared to aero wheels.
If you are not fitting aero wheels to an aero bike, when you have climbing and winds, might as well ride the race bike with regular wheels?
mrblobbyFree MemberI tried taking the aero wheels off the Propel and fitting low profile climbing wheels, and a very noticeable difference in having to work harder to hold high speed on the flat compared to aero wheels.
Just shows how much of the aero benefit actually comes from the wheels. Get the same thing fitting proper deep section wheels to any bike. Stick a set of 404’s on my TCR and the bike is noticeably quicker pretty much everywhere than when on the shallow wheels that came with it.
I can see why they persevere, but OD2 is a bit of a PITA. Already on a M/L TCR (the smaller of the sizes that fit) with a slammed 140mm -10% stem, about as long and low as I can get it. At least there are a few more options now on OD2 stems than there use to be.
monkeyfudgerFree MemberI keep looking at aero frames but seriously, **** that, you’re talking about £1500+ for negligible gains. Raced at the weekend and seeing one smashed up carbonz frame was enough to stop my wants for another 12 months. Deep wheels and aero bars (probably my next purchase) will get you 99% of the equipment gains, add a skinsuit and a decent position and you’re there. Still not got an aero helmet, I’m not ready to look like a pleb 😛
I’ll stick with an alu TCR.
monkeyfudgerFree MemberI thought Giant had ditched OD2? Just bought the Mrs the lower end Envie and just assumed the higher ones would also have a normal stem.
mrblobbyFree MemberStill OD2 on the Propel SL frame and the 2016 TCR.
Envie claims to have a Hybrid Overdrive… no idea what that means.
😳 I do rather like my Air Attack though. Again noticeable difference and I didn’t like going back to a normal vented helmet.
monkeyfudgerFree MemberHa, that’s the problem, I considered an Evade but I’ve clearly got a bulbous head, it doesn’t fit right at all! I think the Evade looks decent but unfortunately I’ve got a Giro head, the Air Attack is particularly wrong looking IMO, and no doubt with the above bulb heeed it’ll look worse 😆
I’m sure you look lovely in yours though 😉
mrblobbyFree MemberI’m sure you look lovely in yours though
I’m pretty sure I don’t 🙂
monkeyfudgerFree Member😆
I want to try one of those Lazer’s with the aeroshell cover but there’s no data around at all about ’em. It looks aero but that doesn’t mean it is.
eshershoreFree Memberthe Advanced Pro road frames all use a OD2 full carbon fork with 1.5″ steerer which requires a OS (1.5″) stem – you could get these from Giant, Canyon, Ritchey, Syntace, Pro and now Zipp but limited in supply and choice of degrees / length
the Advanced road frames use the ‘hybrid’ fork which is a carbon crown and blade, with aluminium alloy taper / 1.125″ steerer
This slimmer steerer can be a benefit for riders wanting a more aerodynamic position as you can get aftermarket stems with very aggressive angle (i.e. -17) for a low aero position
If you look at the Envie / Propel Advanced the head tube is also a slimmer frontal cross section(from having the smaller steerer inside), but I’d guess you’d see more aero advantage from being to run a lower drop front end for the rider, than the actual head tube front area?
TiRedFull MemberI’ve been lucky enough for the past year to have access to Giant Defy Advanced Pro, Giant Propel Advanced Pro and Giant TCR Advanced Pro bikes
And I am fortunate enough to have two of these three. My Defy and Propel are very different rides indeed. The Propel does feel faster, it is heavier and it handles a little quicker. The Defy is lighter, slightly less fatiguing and mine shifts better (Dura Ace). If I had to keep just one, it would be the… TCR Advanced SL – with aero SL wheels. It slots in the middle so would be a good compromise.
At this price and technology point there are no bad bikes, and it’s just subtle flavour changes, depending on conditions. All that said, I’M GOING RACING TOMORROW!!! The siren call of vets racing on the New shiny white Propel is too hard to resist 😀
EDIT: As for the OD2, it’s a pain as stem choice was limited to Giant and Ritchey and the 5mm options are not cheap. Degenkolb runs -17 degree slammed stems, and previously the team ran Shimano PRO stems despite them not being available to the public. I believe they are now.
aracerFree MemberGiven the same geometry as well, yep a diamond frame in any material is stiff enough in the vertical direction to have no effect on comfort. Different geometry makes a difference, but we’re discussing race bikes where that is pretty constant.
PeteG55Free MemberI think aracer actually needs to go ride these bikes, working in the trade means I’ve test ridden quite a few bikes over the years. The last generation of aero bikes were a lot stiffer than their endurance or conventional race frame stable mates.
Ive ridden the older Scott Foil, Spec Venge and Ridley Noah Fast in recent months and I wouldn’t want to do big distances on any of them (not in this country at any rate). The Noah Fast was so harsh, I reckon you could tell what day of the week the tarmac was laid. But I could see why Griepel used it, stiff as a stiff thing when you got on the gas, brakes were appalling though!
The new Noah SL and Canyon Aeromax are a lot better and I can imagine doing a days ride on those worth too many issues.njee20Free MemberGiven the same geometry as well, yep a diamond frame in any material is stiff enough in the vertical direction to have no effect on comfort.
Mad.
FunkyDuncFree MemberSo do Pro’s literally get an ‘off the peg’ bike?
I’m from a skiing back ground where even at national level you could get factory skis that were very different to the same badged stuff you could buy in the shops. If you got to World Cup level you could even specify how the ski was made.
Ie when Salomon first started producing skis and their marketing was all about foam core skis, their pro racers were having wood cores.
In the old days I thought Pro’s used steal frames made to measure, and I just assumed this was still the case now?
Also are pro frames not filled with a heavy substance around the BB to make them meet minimum UCI weight?
eshershoreFree Memberit depends on the rider and the factory producing their frame?
I’ve seen pro frames broken (that I was asked to strip and rebuild with a new frame from the supplier / sponsor) and some were completely stock, others were obviously heavier than stock with thicker tubing or reinforcement in key areas. Other had custom geometry like small seat tube frames with longer top tubes and custom head tubes?
I’d assume the heavier frames had that done to stiffen a frame in a beneficial way to meet the UCI minimum weight rather than just adding ballast!
Also seen factory wheels that looked stock but had different spokes / lacing, reinforced spoke beds and higher tension to the regular aftermarket wheel, again I assume in an effort to stiffen the wheels, typically on deeper section aero wheels for sprinters which even us mortals can get to flex, let along someone like Kittel or Cav going full gas?
chakapingFree MemberI think aracer actually needs to go ride these bikes
Why would he want to do that when he’s got his lovely theories?
tlrFull MemberCould those who are suggesting that deep section wheels are not as stiff as shallow wheels please explain why?
I’d always assumed that deep wheels were stiffer as the spokes were shorter (proper carbon wheels, not shallow rims with fairings).
TiRedFull MemberSaid it many times:
handling = geometry
stiffness = tubing diameter
weight = materialBikes with the same geometry will handle the same, but comfort and stiffness are big factors in how a bike will feel. Bikes have almost no vertical compliance but a 0.5cm flex in a steel-framed BB is not hard to achieve. Also cornering, which is where most handling changes are felt, will load a frame laterally – hence stiffness will come into play.
Most modern road race bikes are now settled on 73 degrees parallel for medium frames. It is however pretty rare to find two bikes with IDENTICAL geometry (all tubes the same length). Boardmann, Merida and Giant TCRs had. Propel and TCR do too, but stiffness will provide real world differences.
thisisnotaspoonFree MemberBikes with the same geometry will handle the same, but comfort and stiffness are big factors in how a bike will feel. Bikes have almost no vertical compliance but a 0.5cm flex in a steel-framed BB is not hard to achieve.
I agree to an extent but that’s not to say you can’t maximise lateral stiffness and vertical compliance, even if that means there’s till more movement sideways than vertically. In fact some sideways movement is probably good, it keeps the tyre on the road rather than skipping off it.
Depends where you measure too. Cannondale stereotypically had large downtubes and skinny seatstays and top tubes to keep the BB and headtube aligned, but the thinner tubes in the stays and top tube let the wheel move up and down. Then you have to decide how you define vertical stiffness, is it relative to the saddle (which will move even further as the seatpost will flex) or the headtube, which may be similar if the top tube is bending a comparable amount to the seatpost but the effect isn’t additive.
philjuniorFree MemberReading Mick Burrow’s thoughts on vertical compliance (basically even a fork has negligible flex compared to the tyre when you actually test it), I’ve got to say tyres, saddle and perhaps seatpost/bars may have an effect. Flexy frames are just going to sap your power.
It may (I don’t think it is, but I’m not so sure) be that some materials and arrangements give more harshness due to less damping of the road “noise”, or even a resonance with it. Certainly when you hear a TT bike going along a road it makes a racket, perhaps this resonance gives discomfort in the saddle.
aracerFree MemberThey’re physics. But then we know that doesn’t apply to bicycles.
I did structural analysis of a diamond frame a while ago – unfortunately can’t find the numbers now, but there was about 1mm of vertical movement at the top of the seat tube when under enough vertical load to bottom out a 23mm tyre. That was for a steel frame with standard tube sizes, which I presume those people who measure vertical compliance by riding bikes (which is clearly a more accurate way of measuring) would describe as being nice and comfortable.
http://bikesnobnyc.blogspot.co.uk/2007/08/bsnyc-2008-dream-bike-shootout.html
PeteG55Free MemberI suspect it’s got more to do with how vibration is damped and dispersed throughout a frame than straight forward flex. As a rough guess, the shapes required for the first gen aero bikes have meant far more was transferred to the rider than more conventional frame shapes.
aracerFree MemberYou’ve seen my analysis? Could you forward it on, as I mentioned above I’ve mislaid it.
With the amount of flex involved, there isn’t going to be much in the way of vibration damping. For that you need flex.
njee20Free MemberI’m really struggling with this I must say.
A bike made from steel girders will feel just the same as one from balsa wood, you’re saying? There is no difference whatsoever, and it’s all in the minds of folk? Every person who’s ever ridden a bike.
molgripsFree MemberFlex and vibration damping aren’t the same at all. However, do you really need small vibrations damped? Do you simply want the edges taken off the hits, perhaps? In which case vibration damping might do that, by damping out the higher harmonics.
Seems to me that the physics brigade aren’t sure what they are actually modelling…
aracerFree MemberNo, that isn’t what I’m saying at all. Firstly the one made from balsa wood will have vertical flex, but then all materials actually used for bike frames are a lot stiffer than that. Secondly there is a significant difference in the lateral flex between different bike frames which can be felt.
Did I suggest they were? However in order to have vibration damping you have to have flex. An infinitely rigid structure obviously won’t damp any vibrations at all.
njee20Free MemberEh? You proferred your opinion to demonstrate that aero bikes feel no different to non-aero bikes assuming the same seatpost, geometry, tyres and saddle. you then said this was the case entirely regardless of material. Now you’re not?
Where does that end? Why does the balsa wood/girder example not count?
Or are you now saying that differences in lateral stiffness make a difference to the comfort? In which case we can just ignore your last few posts and move on.
aracerFree MemberRegardless of any material bikes are actually made from which is stiff enough to avoid awkward things like tyre rub – apologies for not specifying that. Which wouldn’t be the case for one made from balsa wood. I was trying to avoid simply pointing out that it was a poor example – of course if you’re going to use unrealistic extremes then yes there will be a difference.
No I’m not suggesting lateral flex will make a difference to the comfort – though thanks for agreeing with that one. Simply that it makes a difference to the way the bike feels when riding, hence people can tell the difference even if they’re not detecting what they think they are.
The topic ‘Why arent all road pros on aeto bikes?’ is closed to new replies.
