- This topic has 73 replies, 43 voices, and was last updated 11 years ago by lipseal.
Why are so few FS frames made from steel?
jimbobrightonFree Member
Simple enough question really – I can only think of the cotic rocket.
is it so that you can bend ally into weird wonderful shapes and make it look dead sexy compared to steel?
Or is it that the inherent advantages of steel like a bit more compliance etc become redundant when you start to use full suspension?
Just wondering like.
jamesFree Membertheres a downhill bike. k…something I think? (and not knolly, khs, kona)
one or two others I think Ive come across(on the interwebs). Dirt jumpy-ish things
EDIT:
One of which being the DMR Bolt
[125mm rear/120-150mm fork, concentric BB/chainstay mount]mattjgFree MemberAFAIK: Steel is flexi, when made into tubes small/light enough for a bike frame. You don’t want that in a FS, that’s what the S is for. You want the frame rigid.
mattjgFree MemberIt’s too heavy
A kg of steel weighs the same as a kg of carbon. But maybe you are being ironic.
cynic-alFree Memberease of machining bearing housings etc.
alu = lighter stiffer frames
lots of taiwanese factories ready to weld it…
davidtaylforthFree MemberKeewee did one
BMW have done a few
Balfa did half a oneNot many others I can think of, a few smaller companies/one man band affairs but I dont think you can really count those.
jimsmithFree MemberI got a keewee chromo 8
indestructable i reckon
but so so heavy… good for uplift days
weight makes it pretty stable 🙂
light steel flexes…. not good for pivots/linkages etc i reckon
would love to try the cotic thoughjulianwilsonFree Memberfront triangle of a K9 dh frame is steel but not the back. IIRC there used to be an all steel Identiti single pivot dh/fr frame a few years ago too.
A friend of a friend has a BMW (racelink?) and it is well-ard! Weighs more than any expensive bike I have ever handled, apart from my mum’s old pashley princess maybe! 😆
pslingFree MemberSteel tends to be used by bijou manufacturers and they tend to build/assemble hardtails. FS frames tend to come from the larger manufacturers most of whom stopped using steel twenty odd years ago. You’ve pretty much answered your own question with the two suggestions you’ve made yourself I’d say.
jivehoneyjiveFree MemberSteel is far from flexy… for a given volume, steel is about 3 times as stiff as aluminium, although it is also approx 3x heavier… however, it’s harder to form into individual and unique shapes for design flair and more importantly marketing purposes, so is left to rust.
(to be fair, I have 3 full suspension steel bikes and whilst the ride characteristics are schweet, and the frames strong the weights are not competitive within the Trail/AM Market, although once you start getting a bit more hardcore (something like a transition bottlerocket) they become more competitive… the DH bike is ahead of it’s time and still a respectable weight today (keewee cromo8)
thisisnotaspoonFree MemberMarketing.
Aluminum is stiffer, lighter and stronger according to the marketing department. In reality there’s rarely more than a smidgin in it, otherwise there woudn’t be both options.
Specialized prototype their bikes in steel (or certainly used to, I’ve seen the prototype post monocoque enduro) as it’s easy to do short runs with steel tubes.
aracerFree MemberSteel is far from flexy… for a given volume, steel is about 3 times as stiff as aluminium, although it is also approx 3x heavier… however, it’s harder to form into individual and unique shapes for design flair and more importantly marketing purposes, so is left to rust.
Which is missing the point that it’s not the material but what you do with it, and that it’s not possible to do the same things with all materials. Aluminium frames are made stiff by using large diameter tubes. If you used steel tubes of the same diameter as commonly used for alu frames, then either the frame would be a lot heavier than the comparable alu one or the tubes would have walls so thin (1/3 of the thickness of the alu frame) that it would be extremely fragile. If you use smaller diameter tubes as is commonly the case with steel frames then you get a lot less stiffness – the bending stiffness of a tube is proportional to the 4th power of the diameter, so making a tube just 20% smaller in diameter makes it less than half as stiff.
It’s not just marketing – an alu frame optimised for stiffness will be significantly lighter than an equivalent steel frame (that or the steel frame will be a lot less stiff). The reason there are both options is actually where the marketing bit comes in!
NorthwindFull MemberThink the Rocket is demonstrating one of the good reasons not to use steel- just look how many people say “It’ll be heavier than the competition because it’s steel” (which it isn’t), or “steel is flexy” (when Cy’s saying it was chosen for stiffness).
Reality isn’t always what sells bikes.
bigrichFull Memberbecause Taiwan makes aluminium bikes in a certain way. so everyone submits their CAD designs for a frame, The factories churn them out at a low uint cost.
Switching to steel would require expensive modification of the manufacturing process.
jimsmithFree Memberwell..
Ive ridden one or two steel bikes(!) and they ride smoothly because the frame has a bit of flex built in to it for the reasons aracer so rightly points out. (good summary there aracer)
The swingarm of the rocket is alu.. where the stiffness is needed and theres all the shock pivots to house.
much easier and cheaper to cast or cold forge these in alu, makes sense.
oh an its 853 which is stiffer generally throughout the tube/frame IMHO than the earlier tubesets from reynolds (for example)now can anyone tell me about the stainless tubesets, Im thinking about trying either an off the peg thing or getting something built.
Ive not ridden one an am looking for an alternative to Ti as I have a habit of breaking things 🙁
cheers
JclubberFree Memberbigrich – Member
because Taiwan makes aluminium bikes in a certain wayLOL. Taiwan or whoever makes aluminium bikes because that’s what everyone wanted. If the market reverted back to steel, that’s what they’d go back to making (who do you think used to make all those steel frames…)
The problem with steel when designing for light weight is that if you make the tubes small/light enough then the wall thicknesses start to be an issue as they get very thin – they become very easy to dent or do a beer can to – eg crumple.
Steel is a fantastic material if you don’t mind a bit of extra weight – on something like a FR bike for instance (the aforementioned Cotic)
clubberFree MemberIve ridden one or two steel bikes(!) and they ride smoothly because the frame has a bit of flex built in to it for the reasons aracer so rightly points out. (good summary there aracer)
Depends on the frame design – None of my steel bikes are particularly flexy/springy – certainly not more so once built up than my large Alu tubed Pace RC303 (before it broke 🙂 ) which had a very long seatpost…
theendisnighFree MemberThe swingarm of the rocket is alu.. where the stiffness is needed and theres all the shock pivots to house.
no, the stiffness is needed in the seat tube, which is steel, and thats the main advantage of the design to my mind.
wreckerFree Memberaracer has answered the questions very accurately.
I’m not buying it for a second that Cotic know better than all of the other (considerably more experienced and skilled) manufacturers.
Not heavy? 7.6lbs for a 16″, it’s heavier than that Foes Shaver which everyone was saying was heavy lest week (and the foes has more bounce).no, the stiffness is needed in the seat tube, which is steel
Rubbish! Why would the seat tube need to be stiff on a FS bike!??!?!?!
chiefgrooveguruFull MemberRubbish! Why would the seat tube need to be stiff on a FS bike!??!?!?!
Absolutely, it’s obvious to anyone that the pivot mounting points don’t need to to be as rigid as possible – everyone wants the back end of their full-sus to not only pivot on the designed plane but also flex laterally and twist… 🙄
pslingFree Memberthepodge – Member
Would people be interested in getting custom steel frames for under £500?They would be standard 4130 and with a limited spec such as you could only choose 1 kind of dropout (horizontal or vertical) not one of 20 styles of H or V dropout or for head tubes any one of 3 lengths.
Really your main options would be geometry.
I have the chance to work with a frame builder but I don’t want to start bothering him with all sorts of questions and ideas unless there is some real interest as there is nothing worse than some one taking up loads of your time and then never placing orders.
Posted 7 months ago # Report-Post
Come on thepodge, wipe away your tears and share your knowledge with us…
wreckerFree MemberAbsolutely, it’s obvious to anyone that the pivot mounting points don’t need to to be as rigid as possible – everyone wants the back end of their full-sus to not only pivot on the designed plane but also flex laterally and twist…
The effect of which is miniscule when compared with the effect of rigidity provided (or not) by the swingarm. 🙄
thepodgeFree Memberpsling, stop stalking me…
I’ll have my first frame through in a couple of months (curse you transportation by sea) then I’ll know what kind of quality is on offer, there has been talk of previous frames being a bit “slap dash” shall we say
D0NKFull MemberI know bugger all about engineering and material science but all the bike mag articles on bike frame materials I’ve read over the years suggest pretty much what aracer said.
No idea how factually correct those articles are mind.
JonEdwardsFree MemberThing is, the material is somewhat irrelevant to us, the end users.
The frame components of a full sus need to be stiff enough to tie the various mounting points together without flex compromising the bikes performance, and it needs to be tough enough to survive the usage it’s likely to be put through over a reasonable lifespan. How it’s achieved is the bike designers problem. We’re only interested in how the finished product rides.
For an abuse friendly 150mm bike, there seems to be relatively little difference in weight between steel and ally frames, not so sure about carbon stuff thats appropriately stoutly constructed, rather than built to be superlight. Also bear in mind that on a slack 150mm bike, wheels and tyres (and other components) need to be relatively strong to cope with the kind of riding that kind of bike encourages. A few g +/- on the frame is irrelevant.
I’ve spent about 10 hours on a Rocket (and only the chain stay and droplink are ally, the front triangle and the seatstay are steel). One of the least relevant things about it is the frame material. It’s way stiffer than my Uzzi. It handles beautifully and it munches technical climbs for breakfast. The demo bike was 5lb lighter than my Uzzi (which is as light as I can get it without compromising performance). About the only relevance the frame material has that I can think of is that the downtube is slightly less likely to get covered in dinks from rock strikes.
brantFree MemberThing is, the material is somewhat irrelevant to us, the end users.
You’d think so, but material and wheelsize are things used to sub divide categories in bicycling. It’s the way it is.
People look for “853 frames”, “650B bikes” rather than “bike to ride across X”.thepodgeFree MemberRead cy’s lengthy and informative blog on the issue, that tells you everything you need to know
pslingFree MemberOne of the least relevant things about it is the frame material
Which brings us neatly back to the OP’s original question. To the designers and manufacturers it obviously does have some relevance, and to Cy (of Cotic fame, an engineer) it was relevant enough to specify steel tubes as part of the design. But why? To be different?, to improve performance? cost?
Edit: I should obviously stalk you more quickly thepodge (rather than actually work between posts) 8)
chiefgrooveguruFull MemberThe effect of which is miniscule when compared with the effect of rigidity provided (or not) by the swingarm.
If you’re a mechanical engineer then please let me know what you’ve designed so I can avoid buying it! And if you’re not, then maybe you should stop disagreeing with one because your arguments are totally flawed. Do the words “leverage” and “torsion” mean anything to you? Or maybe the phrase “second moment of area”? Honestly…
legendFree Memberthepodge –
Member
Read cy’s lengthy and informative blog on the issue, that tells you everything you need to knowObviously that’ll be a completely un-biased view from a guy who is trying to sell steel bikes 😉
chiefgrooveguruFull MemberYou’d think so, but material and wheelsize are things used to sub divide categories in bicycling. It’s the way it is.
People look for “853 frames”, “650B bikes” rather than “bike to ride across X”.It’s the same in most market sectors. With musical instrument amplification it’s speaker size / configuration, magnet material, open/closed/ported, rather than X loud and with Y tone.
Partly due to the tribal leanings of human behaviour, partly due to buzzword marketing, partly due to journalistic inaccuracy driven by the previous point.
kelvinFull MemberCy’s explanation of why he chose Steel for the Rocket: http://www.cotic.co.uk/geek/steel-full-suspension
thepodgeFree MemberLegend, he’d have to design them before he could sell them
He used to sell alu frames, he’s not ruled out selling them again
Read the blog and then come back and tell us which bits are just marketing or biased
IHNFull MemberDo the words “leverage” and “torsion” mean anything to you? Or maybe the phrase “second moment of area”?
Ooh, I love it when you talk dirty…
The topic ‘Why are so few FS frames made from steel?’ is closed to new replies.
