Yep, I use the Superstar ones. They are very similar feel to the Ritchey ones that I used to use. They’re a bit heavier but cheaper. Both comfy, grippy in the wet or dry. Fine.
I’ve also tried the KCNC ones which weigh something daft like 12g. I wouldn’t say these were uncomfortable but were very hard and quite noticeable. They also didn’t respond well to being removed and refitted as they stretched irreversibly. They started slipping in the wet after refitting.
I’ve had no problems removing and refitting the Ritchey and Superstar ones though. Strong hair spray does the trick as they’re a stretchy fit on the bars, more so than rubber ones.
I wouldn’t go back to rubber ones.
