not sure from your post if it is the non-drive that is stuck or not. If it is try this;
Remove the drive side crank,
Remove non drive crank bolt
undo the drive side bb cup, as the left (non-drice side) crank hits the frame and you continue to unwind the drive side bb cup, the frame will/should push the non-drive crank off.
this usually works because the driev side bb cup is part of the bb cartridge, and as you unwind it the whole bb unit comes out of the frame, axle included. However, if you have a un71/2 bb the right cup may come out of the frame leaving the axle unit in their, then you are pretty stuffed.
May damage/scar the frame but you say it is scrap anyway
Or,
Ride the bike about fr a bit with no crank bolt, will damage the tapers as the crank works loose, but it should come off. Then walk home.
Or,
Cut the crank off
Or, drive a wedge between the frame and crank, kills both, but both are stuffed anyway
I would never want to re-fit a crank with a stripped thread, makes it kinda hard to get back off:) Once you have it off, by a new left crank
