2.5 130 LWB T5 here….
bought it with ~95k miles, now with 123k miles. original clutch, water pump etc… only things that hve been replaced are the front discs (by previous owner) and the rears by me.
supposedly the 2.5ltr needs a little more looking after/regular servicing than the 1.9, but if servicing is done at regular intervals then there shouldn’t be a problem. before you buy it get it checked and looked at properly.
the low down grunt of the 2.5 over the 1.9 is nice, particularily if you live somewhere that isn’t flat and the sixth gear is good for motorway cruising (well, any cruising, tbh). fuel economy is about the same for both engines. my bus hs returned a steady 7.2l/100km over the last 3500km with a mix of autobahn/A-roads and a little town (40/50/10% roughly). i don’t work the engine hard (other when picking up speed on the sliproad) and am rather a sedate driver (top speed generally 65mph-ish when on the Autobahn). consumption will drop off dramatically when cruising at 90+mph, but in the UK that shouldn’t be a problem.
turning circle of the LWB really isn’t a problem. have been up many mountain passes and through italian hilltop villages without any mishaps. although i remember in Final Ligure we had to do a five point turn to get around the hairpin. normal cars could do it in four.
[/url]DSCN3452_edited.jpg kontrapunch by sod_the_taxman, on Flickr[/img]
