The point of the bike is to expand my options, not limit them.
that basically
Out of interest what are your extreme ratios?
Outwith what I’d get with 2/1x setups.
that too
Ah ranges with no numbers 😉
We did the numbers the other day on the other thread (and mine was a cut+paste from before)
Give me a 9-56 tooth cassette option, and then I can have the range and ditch the overlaps that aren’t really overlaps unless you are clumsy enough to change a front ring and then crank the chain back 5-6 sprockets.
Current 1×11 approximately make me lose 1-2 bottom ratios, lose the big ring ratios entirely, and in the case of XT, lose the fastest ratio of the middle ring. I could nudge that a bit either way but what you gain back at one end you lose at the other.
I use 1st and 27th too, and lots in between.
So I have a 1×9 plus a few bonus lower gears that I can select with a button when I go up. And a few bonus higher gears too, also selectable by a button, for when I go down.
