kayla1 – Member
Any chance for something wider? 7-10mm preferably…
No
The cost (time & material) of machining 7-10mm down to 2-3mm pushes the cost up. There’s a good reason why wide base stainless cogs are more expensive than narrow base ones! I’ve swapped my freehub for a steel one because of that.
How about making a wide carrier? The cog could be bolted to it.
Then cogs could be changed with hand tools carried on the bike.
If the hole spacing on the carrier was the same as a 6 bolt disc carrier, you could also sell the cogs to fixie community who use modified disk hubs, and also to the fat bikers who do expeditions, because then if their freehub freezes up and becomes useless they have a bail out gear.
I would buy a carrier and cogs of assorted sizes.
