got one of these...no trouble with last winter on the road....obviously doesn't take the pasting a mountain bike takes...
Are there any long term reviews of belt drives out there ?
Not press releases or magazine reviews, but opinions from people who have paid for it with their own money and ridden it for a few months.
Think there might have been a few people who have ridden round the world on belt drives. Worth a google if you're interested.
Here we go, I found the prices.
£170 for the belt and two pulleys plus another £35 for the snubber, then another £28 for the special tools.
Edit;
The link seems to be too long to work embedded.
Try copy & pasting this.
http://builder.nicolai.dbap.de/index.php?screen=dstore.config&fid=42&step=4&modell=&is_mcheck0=1&mammount0_1=1&mcheck0_1=1862&mammount0_2=&mammount0_3=&mammount0_4=&mammount0_5=&mammount0_6=&is_mcheck1=1&mammount1_1=&mammount1_2=&mammount1_3=&mammount1_4=&mammount1_5=&mammount1_6=&mammount1_7=1&mcheck1_7=1910&mammount1_8=&mammount1_9=&mammount1_10=&mammount1_11=&mammount1_12=&mammount1_13=&mammount1_14=&mammount1_15=&mammount1_16=&is_mcheck2=1&mammount2_1=1&mcheck2_1=1864&mammount2_2=&mammount2_3=&mammount2_4=&is_mcheck3=1&mammount3_1=1&mammount3_2=&mammount3_3=1&mcheck3_3=1901&mammount3_4=1&mcheck3_4=1919&mammount3_5=1&mcheck3_5=1983&mammount3_6=&mammount3_7=&mammount3_8=
@Brabus and MTQG, With regard to the 'e-stay' requirement or similar, how about a replaceable dropout which completes the right hand triangle? Whyte use a similar thing to adjust either wheelbase or chain tension when used as a singlespeed. like this:
linky
take away part of the vertical section between the two sets of bolts, using the dropout as part of the frame. For belt removal, wheel out,unbolt dropout.
I've seen people do that. seems the easiest way to me but most seem to have a split in the seat stay.
saw a couple of belt drive bikes at SSWC yesterday.
I have a Trek District, been very happy with it as an everyday bike.
timing belts in infernal combustion engines have annihilated timing chains
You should be an engineer.
He was
Oh, a bit of an aside, check out ecovelo.org for a blog on general utility bikes, including belt-drives and Alfines.
I'm seriously considering getting a belt drive bike, but they don't make it easy, do they ?
Van Nicholas do a Zion 29er, but they only list the 26er for belt drive. I'v emailed them to ask if there's likely to be a belt drive 29er soon.
I did a search for Zion on here and I found a warranty replacement one for sale.
It was shortly after searching and finding two warranty replacement Lynskey frames on here that my own Lynskey cracked, so that's not a good omen.
Nicolai do a 29er Argon for Rohloff & Gates. £1275 for an aluminium hardtail frame though. That's more money than a titanium Lynskey or Van Nic for a heavier frame. It's also £100 more than the same frame on the German website.
There's nothing on the UK site about belt drives and not much on the German site either. No mention of the new centre drive. I had to cross reference with Gates' own site for advice on gear ratios and belt length.
No mention of Lefty either, although there's pictures of at least two Argon Leftys on the web.
Maybe they just haven't updated the website and if I contacted Nicolai UK directly they could answer all my questions.
Just get a normal ss frame and get the seatstay split by a frame builder.
crundi - Member
An interesting read...
here
no it wasnt
What bandito says the frame needs to be stiff enough I have a belt drive set up for sale in classifieds if anyone interested
Al: Just get a normal ss frameBandito: Not all "normal" frames are laterally stiff enough to keep the belt aligned...
They are if you add spoon and candle wax bracing spars...
so you want a mrk1 santa cruz chameleon then.
Van Nicholas emailed me back.
They'd want an extra £440 as a custom build on top of the normal frame price for a belt drive ready Zion 29er with a Lefty head tube.
Nicolai list the parts and prices for all the belt drive stuff on their website, but they don't mention the sprocket adapter needed for Rohloff, there's no advice on which belt length is needed and they don't say whether it's the older style belt or the newer centre track.
It's as if they're trying to put people off buying it.
At £1275 for a hardtail aluminium frame, that's 3 times the price of a Chumba HX2, I'm finding it hard to justify buying an Argon.
Maybe when the winter comes and I'm adjusting my chain every day, I'll change my mind though.
Ringo, you need to specify the belt length so I can work out what chainstay length it will suit.
http://www.carbondrivesystems.com/downloads/tech_docs/Belt2Gear_Calc.xls
The adjustable dropout system on the Whytes mentioned previously is the best system I've come across, but could not be modified for a belt drive, as the chainstay/seatstay is welded to form a complete triangle. The plate dropout just covers it.
Interested to know how you get on MTQG. This is the way forward I reckon.
(cough)hacksaw
For commuting I would love Genesis to do the day one alfine in an 11 speed belt drive spec. That would be the ideal commuting bike for me. With full guards it would be perfect. Slightly heavy but the weight isn't an issue.
Please make one Genesis, thank you.
This guy does conversions to steel frames to take belt drive.
its a 118 belt greaham so around 450mm stays
does anyone else do belt drive parts? they seem a little expensive to be experimenting with at the moment
Nope not in the same league as gates my kits a cheapish way to try
The Orange/Strange prototype uses standard 8mm pitch belts rather than expensive Gates Carbon drive
You must log in to post.
