Viewing 40 posts - 1 through 40 (of 44 total)
  • who gives way, ascenders or descenders?
  • scruzer
    Was out in peaks yesterday on a fave descent and met 4 riders coming up. Now when I am on the up (on singletrack this is…)i always pull over to let the descenders by. Was a bit miffed these 4 seemed to show no consideration for my grinfactor… and ploughed their way through me! Though they were 'friendly'. What do you lot do, trail etiquet and all….
    rolfharris
    Asceders should give way. Always. The descent is all about enjoying yourself, and the climb is just about getting there.
    iDave
    i always thought ascenders had ROW?
    easier for descenders to get started again…….
    racing_ralph
    depends – if its a tough uphill and the ascenders are near the top, then i stop to let them complete their personal challenge – and vice versa
    jamesgarbett
    I tend to give way to descenders just as an excuse for a rest!
    simondbarnes
    Descenders should give way.
    brakes
    ascenders should get out of the way
    pain should give way to pleasure
    allyharp
    I tend to give way to the ascenders (as long as they're on their bike).
    Once you stop it's often too difficult to get going again so I'll give them the chance to keep going.
    I think descending is still great fun even if it is stop-start. Climbing is mostly only fun if you clear a challenging climb, and I'm not going to spoil that little opportunity for somebody.
    druidh
    allyharp – Member
    ballsofcottonwool
    Descenders should give way and hold gates open for ascenders. If a descender can't stop they were going too fast.
    TandemJeremy
    Climbing has priority over descending
    allthepies
    Yup, descenders give way.
    Oggles
    Descender gives way. Same as if you were driving on a steep single track road. It's harder to get going again if you're going up!
    If either party is pushing they should give way though IMO.
    MrSalmon
    I'd say descenders should give way, all things being equal. I could imagine exceptions though.
    theboatman
    Always give way to ascenders, although if I was just about to kick off on a climb and could see someone heading down fast I wait till they hit the bottom. If you're pushing either direction you need to just get out of the way.
    nuke
    Descenders should give way. If I'm descending on the same line as someone ascending, it takes so very little to drop off the line, pass the ascender and then re-join the line in the vast majority of situations.
    J0N
    Ascenders should give way as they are already going slowly while a desender will be travelling fast therefore take further to stop and in doing so may lose control in a effort to slow down and avoid the obstical.
    Ascenders will be going slowly and as a result they can hear more so should be able to hear the on coming descender.
    crazy-legs
    This has cropped up several times before on here. Assuming both parties are riding then the descender should give way. If one party is pushing or stopped at a gate etc then the rider has priority regardless of direction.
    epicsteve
    Definitely descender should give way if possible.
    druidh
    J0N – Member
    In which case they are going too fast?
    Bunnyhop
    Yes Crazy legs is correct.
    glenh
    There's nothing worse than some ****t coming the other way who nearly mows you down when you are trying to ride up a trail.
    mrmo
    On a public right of way bikes MUST give way to all other trial users, if you are decending so fast you can't stop you are out of control and are riding dangerously.
    Decenders should give way to acenders, unless you are pushing the bike up in which case no issue getting out of the way.
    thisisnotaspoon
    whoever's got it easy?
    If someone was scrabbling up a steep loose section and i was decending on a flatter, wider easy section it'd be rude to push them off into the bushes.
    Similarly I'd be pissed off if I was decending and some pillock started up some steep section I was mid way down.
    If you start imagining unwritten rules you just pave the way for accidents, if neither party has "right of way" and both assume they have to slow down we'll all get along just fine 🙂
    MrSalmon
    +1 A good rule of thumb shouldn't overrule some common sense and consideration.
    Junkyard
    where was this was it me /us as I was in a group of 4 in Peaks yesterday?
    We gave way three times to descenders on pi55 simple stuff where we could get going easily and they were flying/descending/enjoying etc. We did not give way on one steep technical/rocky bit as it was both a personal challenge to complete and we would never have got going if we had stopped.
    We were spread out thinly on the ground to be fair though if it was us sorry
    RepacK
    How about a bit of common sense? Whoever its easiest for? Just for info in the US down gives way to up.
    dobiejessmo
    If the decent its steep enough you dont have a problem with anyone coming up.This is a difficult one.
    Teetosugars
    Down gives way to up.
    brakes
    I really don't think it's black and white – very much depends on circumstances
    but if you're not going too fast downhill, you're not doing it right 😀
    cinnamon_girl
    Ladies first in which ever direction I am riding.
    miketually
    Both parties should slow down and say hi, with the descender keeping out of the way of the climber, who has right of way.
    Daffy
    On a public trail, an ascender has the right of way (This should also apply to walkers when bikes are ascending toward them and vice-versa).
    IMO If you're moving too fast to slow down for another trail user, you're going too fast for the conditions and needlessly endangering others, exactly the same as on the road.
    Purpose built stuff is different.
    DaveGr
    Descenders should give way / change their line as it's easier for them to get going again.
    samuri
    The bloke on the rigid singlespeed has right of way, because he's rock!
    Kramer
    I tend to give way to everyone, whether I'm going up or down.
    slowrider
    i find that riding straight at other trail users of any kind usually gives me right of way as they scarper.
    seriously though, if i was approaching a group of walkers id slow in plenty of time, avoid giving us a bad name and all that. if it was bikers id be less inclined to slow down, hoping they had some idea of the fun involved in descending and wouldnt begrudge me my fun.
    D0NK
    Scruzer that wasn't you dropping down the cobbled descent next to kinder res was it?
    scruzer
    thanks for the replies. I will take note. For your information I was descending Hope Bank. This leads from Hope X and runs above the Roman Road down to Aston almost. It was just befor the flat section. Cheers folks
    james
    Surely there is neither has any right of way? Just keep to one side where possible
    Why do people type this stuff as if its fact?
The topic ‘who gives way, ascenders or descenders?’ is closed to new replies.
