My ‘rockshox’ one (they appear under other names) has started to leak around the connecting threads
The head has developed play such that in order to depress the valve on my shock, that the shock pump has to run past the threads on the shock too, and so it won’t engage proper
With an valve extension pipe it still leaks on the shock pump threads
One with a longer connecting head should help with the short threads on my specialized rear shock
Being albe to fold to go in the camelback sometimes would be nice too
I’ve narrowed it down to:
Topeak one
or
SKS one with reinforced connection pipe
I’ve had 2 shock pumps before burst along the connection pipe
Which one would you reccommend (or avoid)? Any others that should suit?
