Lyrik coils would be my choice. Yeah they’re very heavy but they’re also godly, pretty much a sawnoff Boxxer. Mine pretty much ruined me for other forks, my RC3 Tis weren’t as well controlled, the modern Pikes and Lyriks are just not in the same class imo, only my stupidly expensive 2015 36s have been competitive and they’re still not as good. (maybe a coil conversion in a modern fork would do the job but I’d still rather have the mission control than the RCT3/charger damper in the new stuff)
Uturn adds functionality and is reliable, the only downside is even more weight. (uturn is nice in that the fork works correctly at all lengths, and isn’t impaired at all by having the length adjustment- so you can happily run around with it at 130mm or whatever.) It’s slow to operate though.
There’s 2 different dampers, the Mission Control and Mico DH. The standard Mico has a lockout but doesn’t perform quite as well- but you can easily modify it to remove the lockout and once you do that, it performs almost the same. (obviously, it’s a coil so with no lockout it can be quite bobby… Your call on what’s most important, I lived with the blob)
The air is actually pretty good too, but the coil is only 200g more and worth it IMO. I’m pretty sure you can retrofit any of the coil setups into the air fork, should you choose. Don’t under any circumstances buy the 2-step, it is appalling, unless it’s so cheap that you can economically fit a coil.
