…but at 75kg in my b’day suit, I’d rather go with something a bit less fragile.
Any suggestions? I have a 400mm Thompson Elite, at 271g so would like to lose a bit of weight off that – is bad/dangerous to suggest I saw 50mm off of it, as this would still leave 120mm in the frame?
No “go for a dump comments please”, thats a given.
What diameter do you need? Currently running kore t-rail saddle seatpost combo and its pretty light. Tricky to find carbon version but CRC had so me of the alloy ones left.
Note, they only recommend it for XC riding a max rider weight of around 90kg.
Or if you don’t mind getting a new saddle too, I’ve regularly seen SDG I beam stuff going very cheap on CRC. It was a few years back but I picked up their carbon seat post and a Bel Air saddle for around £80 total and together I think they weighted 450g all together. I think that’s a pretty good weight for something rated for all mountain riding? I emailed them to confirm and they were happy with me doing aggressive riding on it.
I have the KCNC posts on ll my bikes. I’m around 73kg at the mo but have been quite a bit more without bending one.
Plenty of cheaper KCNC posts on eBay.
I have USE alien ali posts on 2 of mine. I’m 70kg and although they are a right faff to sort they are very light (254g) 350mm 31.6. Not had any probs even on my ‘bigger’ bike. I have a carbon i beam as a spare one which is heavier.
I’m worried I won’t be with kit on. Remember this is the “one” bike now, so it needs to accomodate an “everday” kit weight with water etc as well as a “race” kit weight which would be lighter.
Actually buying the 400mm KCNC might help, its still 100g lighter but there’d be much more in the frame…
I’ve got one on my FSR and it is fine – few years old now and it’s still straight – I’m around 74kg in my birthday suit. Bit heavier than the scandium one, but still light and has a much higher weight limit. The clamp is great too.
They do it in 400mm as well.
Cutting the seatpost down seems like a bit of a rash move. Would you not have been better off sticking it on ebay to offset the cost of a new post, rather than hack a load off it?
I’m on a large Anthem 29, which really is quite large in the TT, 18mm layback would probably be an issue. My current in-line has the saddle cetral I guess…
The 1990’s would also like to check if you’ve –
trimmed your bars to be shoulder width
fitted foam grips
trimmed your brake and gear cables as short as possible so you can’t turn more than 45 degrees
fitted air-B latex inner tubes
running 28 spokes on the front
fitted Ritchey ‘Z’ max 1.7″ tyres (red front, black rear natch)
drilled holes in your cranks
fitted some flimsy aftermarket QRs
ditched the seat QR
replaced your mech hangar bolt with an aluminium one (and removed at least some of the skin from your knuckles) then zip tied it on
Can’t think of anymore that used to be in the ‘Top 10 ways to save weight’ yearly articles in the MTB mags of the day.
You won’t carry 10kg of weight. Even with the sort of shit most on here advocate carrying for 3 miles around a trail centre! Look at the weight limit for road use too, can’t see it being hugely fragile. I may still have a brand new New Ultimate carbon one alternatively, forget what sizes I’ve got. They’re light. My 27.2 is 123g.
Weight limit for XC is 85kg, you said you’re 75Kg, how much kit do you wear?!
Being that it has a 120Kg limit for road use that implies it’s mor than capable of handling you sat on it, the difference is to account for banging into things off road while sat down, and hopefully you’re not sat down when you bang into things?
Based on above assume the weight limit is a bit conservative too then I’m sure you’ll be fine.
The OEM seatpost (giant connect SL) if set at the minimum insertion mark would only extend 20mm beyond/under the TT junction. I didn’t come with a warning no to do that and therefore…
Having my now 300mm Thomson extending 50mm below the TT junction would seem perfectly safe.
The answer is obviously a smaller frame (which will save you even more weight…. 😆
Cheers, all though I feel I must have some KCNC on my bike (Stem is OD2 so no joy there, bars will be Mt zoom low risers, with Ti faceplate bolts no less).
I reckon this bike is approaching sub 25.5lb now even by my digi-kitchen scale calculations.
njee20 – Member
See I’d avoid KCNC stuff where I could. It’s light and good value, but I think it looks cheap and nasty!
How very dare you!?! 😉
I fitted it to my bike because I thought it looked pretty good (and part of it was because it’s a name you don’t see everywhere).
My seatpost looks quite worn now, I will admit, but I think that’s because to get the bike in my car, I remove the seatpost so it’s in-out all the time.
Funny thing was, although I didn’t buy it to save weight I did expect it to be a bit lighter than the stock Specialized stuff, given the price of it all….but there was very little in it (although the seatpost is longer and bars wider, so perhaps not a fair comparison).
Just goes to show that to save weight you shouldn’t just assume that the standard finishing kit is cheap and heavy!
