Discovered a load of play between the cassette and the freehub on my Yeti's wheel.
The cassette (XT jobby with the alloy carrier) can rotate about half a degree and move up and down the splines of the freehub by about 0.5mm.
The lockring is done up nice and tight, but this doesn't make any difference, as the final cog in the cassette has what i can only describe as 'capped splines' – as in, it can't slide all the way onto the freehub, it is designed to sit on the end.
So, which is knackered? My hub or my cassette? or are they both fine and I'm missing a spacer or something? (I don't remember there ever being one with any hope hub or XT cassette).
Dave
