Ok, so I recently bought a Haibike Heet & although I thought I wanted a FS again I just don’t think it’s for me with that much rear travel 🙁
So the spec is good & I got it for a good price, so rather than sell it on I was thinking of buying a plastic hardtail frame to pin the bits on, so I would need a tapered Head tube at least to use the forks, I will also need an adaptor to use the rear wheel as I can’t find a frame that takes the rear axle. So that leaves the crankset, well I could use some other cranks for a threaded BB & sell the ones I have.
So assuming the above, & IF I can find the rear wheel hub converter could I do better than an OO carbon 456 evo?
I would appreciate any thoughts or info you could give me.
Many thanks!
