Ps does any other company do a similar product?
Check out Works Components before you do anything else, they make a cheaper, better product. I don’t know whether they have one to your spec but they’ll be able to tell you for sure. Weird really, they’ve been making their product for longer, in the UK, but most of the mags only want to talk about the shiny expensive newcomer.
Other options are available, K9 comes to mind and there’s others whose name I forget.
Offset bushings are another good method, but not compatible with all frames- they shorten the “maximum compressed” length of the shock so that can cause frame parts to collide. Worth checking first. They also have other unpredictable effects, since with some suspension designs they’ll mess with the linkage rates.
