Viewing 8 posts - 1 through 8 (of 8 total)
  • which forks are better?
  • astura
    Marzocchi 03 100mm mx comp bomber or RockShox Tora 318 Solo Air OE Suspension?? 85 – 130mm
    iamsporticus
    If they are both 2003 vintage then whichever had been looked after properly
    astura
    the rock shox are 2009
    TandemJeremy
    The zocchis are ( I think) open bath so they will be reliable and very straightforward and simple. The rockshocks are much more sophisticated but as they are more complex and only have small amounts of lubrication oil ( again I think) as they are cartridge forks they are much more sensitive to servicing.
    If the zocchiis have no signs of wear then they should be good. However its a bit apples and oranges to compare
    poppa
    I am guessing that the 85-130mm is referring to removing internal spacers etc. not U-Turn?
    astura
    Thanks,
    I am currently riding the Marz 03 on a 2006 marin wolf ridge, i saw a decent offer on the rock shox for 100 but wondered which would better suit, i do a fair bit of trail riding
    astura
    Yeh, you have to move internal spacers
    robholland
    I would get a second hand set or pikes or revs for £160 or something. Be alot better.
The topic ‘which forks are better?’ is closed to new replies.
