Gravity Dropper. They just work. And on the very rare occasions when they don’t they’re dead easy to fix yourself. When they get graunchy/sticky feeling after tons of use in filthy conditions they’re quick and easy to clean and lube and when they get sloppy after even more use you can buy the parts to properly service them for very little or send them back for a full service for little more.
They’re not smooth feeling in their action, nor do they have multiple positions (up, down and one other). But they’re not suspension forks, they’re seatposts. Does smoothly damped action matter? I just want my seat to be up or right down or occasionally just a bit down for technical climbing.
And if you change frame to one with a different seatpost size you can buy a different outer post and swap the parts – I’ve just done it and it required undoing three allen bolts and unscrewing the top cap and everything comes out of one post and then doing the reverse with the new outer. That’s with the new Turbo LP, which is particularly satisfyingly simple.
And I believe they’re the lightest dropper posts you can buy. Up to 5″ drop in the bigger sizes, and 27.2mm 4″ drop available (I’ve been using one of those for three years with one cable change and one service, about twice a week in all weathers with lots of mud).
Nice little company too, who are extremely helpful – and as far as I know they invented the modern dropper post or at least made the first one that really worked.
