Viewing 9 posts - 1 through 9 (of 9 total)
  • Which cone spanner…
  • lemonysam
    15mm SLX front hub is losening off, lockring obviously not tightened in the factory. What cone spanner(s) do I need, is it the same model as the 20mm version?
    Stoner
    one in a million – I thought they did them up with a scaffold pole!
    lemonysam
    I know, I guess this way is preferable in some respects, especially if I get to pick up a comedy oversized spanner.
    Stoner
    They dont specify the 15mm hub on the shimano tech docs site, Id be surprised if the went for a different lock nut size. I have the big one for my 20mm XT.
    benslow
    Mine was loose too after a couple of months.
    Could do with knowing what tool needed.
    ste_t
    Can you not measure the nut? 20mm shimano hub uses 28mm cone spanner as far as I’m aware
    lemonysam
    Not until i get home tomorrow and was hoping to pick one up before then.
    lemonysam
    So it seems it’s this: http://www.chainreactioncycles.com/Mobile/MobileModels.aspx?ModelID=29170 has anyone actually used one with a 15mm hub? Do they come as a pair or can you get an adjustable spanner on the disk side when you remove the centrelock locking?
    lemonysam
    Ok, that’s not the right one. The sizes are 23 and 26mm for future reference
The topic ‘Which cone spanner…’ is closed to new replies.
